.90ar vs 1.0ar
pizza pig
I Like to Party
Feb 13, 2012
266
CT
I don't see how the secondary is choking the primary. Secondary has an 87mm turbine and i have tried both a 1.0 housing and just swapped to a .90 housing with zero change. I've seen stock turbos put full weigh crew cabs to a 7.0 in the 1/8th so I highly doubt the secondary is choking the primary in my situation.
Agreed. Have you actually capped off the gate? Ive seen some weird things happen doing it the way you are doing it. Another thing to test, food for thought
Hellen Keller sent this?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I had a buddy weld this up for me. I pull the turbo and cap the pedestal. This will test the intake and exhaust side.
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
If you are not gating at all around your secondary all the exhaust energy is being used to make pressure with the secondary. That 88mm is nowhere near its sweet spot at 25psi. If you can find a way to drive it at say 40psi and only run a pressure ratio of two on the primary you should see much better performance.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
This is exactly what I have been trying to do. But i am not able to get it there. I have played with the gate in every way possible. I am seeing the best performance with the gate completely closed. Doesn't matter what psi i start to open the gate at, the secondary just falls right off. I've tried opening the gate at 25 psi, 35 psi, 50 psi...same result every time, secondary just falls off and performance suffers. Supply full boost to the top port to force the gate closed at all times and I see 60 psi and it will run 11.2's with fuel left to burn. Absolutely can not get the turbos to drive any harder.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Just checked for boost leaks again and it is good.
Do you guys think the 1.23ar housing is killing the potential of the atmo? See if i can find a 1.0 housing or what? I'd just hate to spend 500 bucks on a housing (if they even make anything different for the F1 turbine) and see no difference.
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
A housing change may be in order on the primary. A 1.23 is a relatively large a/r for a gt55 sized turbine. I bet a drop to a 1.0ish a/r would help out a ton. I ran a gt47 88mm upwards of 60psi as a single with a 1.39a/r. That turbine section flows probably a good 10-15lbs min less that what you are running now. I think a smaller a/r def help you out.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I just sent Turbonetics an email in regards to the turbine housing. We will see what they have to offer.
How do you think a gt47 would do in place of the turbonetics? The gt47 has a considerably smaller turbine wheel with several options for turbine housings. Ugh:(
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
Not trying to cut up your selection of primary,but it is a fairly large turbine for the compressor size. Something a little closer to turbine exducer would be happier. The tighter a/r will help get the shaft speed up on the primary. Although it may not be enough to reach your goals. Hope this helps!
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Very true. For some reason I was thinking of the smaller compressor 5541. I plan on spraying mine a little bit without a gate and see if I have the same issues as mike as my new engine will have the identicle setup.
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
I believe if it is a 94mm or larger you wont have much trouble. The comp inducer and exhaust exducer relationship is very important. A big spread can be quite troublesome on smaller displacement engines. Now if we had 900ci like a semi truck that 88mm would be spot on.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I also talked with a local shop and he said he could swap in a larger compressor. Kind of pricing out a few different options at this point to see what is the best route to go.
