GMC_2002_Dmax
The Still Master
CP3 Pump Operation
For those who do not know how a CP3 works let me explain.
1) The CP3 uses a regulator to let fuel in or out of the CP3 by altering the MA-milliamps of voltage.
2) Absent any voltage to the CP3 the spring will force the regulator wide open, the voltage closes the regulator and the spring opens it, it is easier to pull a spring closed and then allow it to expand. This also allows fuel to flow if a regulator fails.
3) It is a precision pump, it has tolerences down to the thousandths so opening up internal passages and regulator triangles with a die grinder and drill bit is hardly precision machining.
Anyone who wants WOT/Full flow only needs to put a simple open/closed switch from the ecm to the regulator or when you go WOT it will cut power to the CP3 and it will then go to full open.
This can be done with a relay and DSP output with efi live as well.
OLD SCHOOL........also if you command 0 amps in efi live ( which I do ) in the amperage tables it should in theory ( it does ) open the regulator wide open.
