Well I finally got the truck together after taking it apart to swap my cp3.
The cp3 I had previously was worn out and peaked at 10k psi of rail pressure. It would fall as low as 5k psi. The truck was (still is) tuned with that cp3, stock turbo and 60 over sticks.
I wasn't able to tune it for the new turbo due to rail pressure issues. Well now all those issues are fixed. (bigger lift pump, 85 over cp3)
I just drive the truck for about 45min back home. The truck sounds like a 7.3l power stroke now. It makes loud clatter under throttle up untill 1300-1500 rpm. At a dead stop, it's quieter but still louder than before the new pump.
Is this noise due to having more rail pressure than commanded? I'm assuming that I just need to tune it. But untill then, is it safe to drive around town?
I talked to Trent on this issue. I just want to get other peoples opinions as well. Have Any of you guys who have done cp3 swaps have had this situation before?
Ps... CAN'T WAIT TO GET IT TUNED!!! She should run like a rapped ape. Finally should be in the 11's!!!
