45% overs and ARP's this weekend
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
what did you do to fix it?
TIGHTEN DOWN THEW BOLT THAT WAS LEAKING AIR/WATER :eek: IT WAS FINGER TIGHT AFTER CHECKING IT :eek: :rofl::rofl::rofl::rofl::rofl::rofl: i WILL NOT SAY THIS LITTLE PROBLEM WONT COME BACK BECAUSE FROM RUNNING IT THAT WAY I COULD HAVE DAMADGED THE GASKET BUT AS OF RIGHT NOW THERE IS NO COOLANT COMING OUT OF ANY ORFICE OR BUILDING PRESSURE AT IDLE .
EDIT SORRY FOR THE CAPS ....
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
thanks for sharing Trent.
SteveFord
What's Next?
May 8, 2008
1,317
Iowa
You know what this means...........time for a 10 second pass!! Good luck!!
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Sweet find Trent, my fingers are crossed for you! Hope we can run ten's side by side at the end of the year.:hug: (Youtube History is on the line):rofl:
Sweet make sure you get the part of you both getting your butt's chewed for not having rollbar's :spit:
9,906
152
Was it one of the middle bolts Trent? I know when we did Simon's after we stretched all the bolts and torqued everything down, we let it sit for 12hrs and sure enough there were a couple that were loose. They were in the middle-the ones you are supposed to start with.
TrentNell
Jul 7, 2008
7,543
slc tuah
I doubt you forgot to tighten it Trent ....Probably just stretched;):D
Very good news:cool2:
I like your version better Simon :D
no it was the outer bolt right above the end glow plug drivers side , I am pretty certain i forgot to tighten because it was the very last stud i did on that side , and it was like 4:30 AM , i called it quits the night and was supossed to finish that stud the next day and think i just moved onto the next side .
I went out and checked the upper Radiator hose this morning and not much pressure after sitting overnight then cracked the cap and no air came out ..... I will be driving this weeking to see if i can make it do something but as of right now i have top say its good :angel:
KEVINL
1,431
Phoenix, AZ
The reason you are supposed to tighten and loosen the bolts 4 times is because they stretch. But they are not supposed to stretch after that
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Interesting....yet after leaving them over night the #2 bolt in the tightening sequence was under tq on both sides
These bolts where stretched 4 times and left over night.
I realize what is supposed to be GOOD but it wasnt
TrentNell
Jul 7, 2008
7,543
slc tuah
I think when you are starting with a fresh gasket it becomes alot more important to re-check because the gasket will "squish" and could settle after a bit. But i am def no expert , I botched up my own head stud job :joker:
KEVINL
1,431
Phoenix, AZ
That is kind of scary. I have about 3000 miles on my HG and studs. I am keeping my fingers crossed
9,906
152
I think when you are starting with a fresh gasket it becomes alot more important to re-check because the gasket will "squish" and could settle after a bit.......
You could be right. There must be a reason GM reccomends waiting 12hrs and then retorquing-that could be why.
