14" Rotors with stock calipers
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
How close is it? Is it "just barely"? IE, if you got creative with a grinder on the calipers, do you think would 17's fit?
gmduramax
Shits broke
Jun 12, 2008
4,073
249
Nor cal
The stock 17's were tapered I'm not sure if all 17's are like that. I have some H2's I can try. If it wasn't tapered I think a little grinding on the caliper would have them fitting.
Lennart
Not from here !
Aug 10, 2006
305
Detmold, Germany
Old thread I know, but is the bracket from the 4500 rear the one that will work in this application?
What part number bracket is that?
A rotor that looks very similar to the one from SSBC is the front C3500 from 1993, which is:
Bolt Hole Circle Diameter - Inches 6.5
Part Thickness - Inches 1.535
Outside Diameter - Inches 14.255
Center Hole Diameter : 5.13"
Height : 3.21"
compared to stock:
Bolt Circle Diameter : 6.5"
Part Thickness - Inches 1.54"
Brake Rotor Diameter : 12.79"
Center Hole Diameter : 4.65"
Height : 3.51"
Center hole is a bit bigger, might need a centering ring and perhaps a spacer
of 0.3" (7.5mm) to get the caliper aligned.
prostreeter600
Street rodder
Jul 18, 2010
895
Dallas Tx
Will those 14.25" rotors work with 18" wheels . I know the question was asked if they would clear with 17" wheels and I believe they would not . The recommended wheel is 20" but in my case I have 18" and I was considering the upgrade .
gmduramax
Shits broke
Jun 12, 2008
4,073
249
Nor cal
I'm pretty sure they would. NBS 17's almost cleared. I don't have any 18" rims to try on it though.
3,727
296
If you ever got the chance to try the H2 rims, I'd be interested, as that is what I run.
I suspect it won't fit, though, as they don't seem to have much clearance to the stock size brakes.
