14" Rotors with stock calipers
ripmf666
15,123
14
47
Wentzville Mo
Front
Rear
redneck191218
Jun 20, 2010
21
gmduramax once you get the right rotor and spacer would you mind posting or PM me the SSBC P/N I think a lot of people are interested. I'm about to do a full brake job 130,000 miles on the stockers.
gmduramax
Shits broke
Jun 12, 2008
4,073
249
Nor cal
Caliper relocating brackets? This is going to sound stupid, but how do those work?
ON EDIT: I figured it out. Anthony, can you measure the distance between the bolt holes (that mount to the spindle) and the bottom edge of the brackets?
9 and 9/32's inches from center or holes. Center of hole to bottom is 24/32's inch
gmduramax
Shits broke
Jun 12, 2008
4,073
249
Nor cal
Here's my problem. SSBC's solution, they're sending me spacers to push the bracket out. WTF don't buy this kit from them.
ImageUploadedByTapatalk1370534886.058802.jpgImageUploadedByTapatalk1370534900.268459.jpgImageUploadedByTapatalk1370534914.587720.jpg
1,868
Ok, I also need one more #....from the spindle mount holes to the caliper mount holes. Sorry, thats probably what I should've asked for initially.
How tall is that rotor and what's the width of the braking surface?
If the rotor is shorter than 3", you arent going to find another close to it. Ive been searching for a shallow-hat rotor like that for a while.
BTW, is the rotor seated down on the hub completely?
ripmf666
15,123
14
47
Wentzville Mo
I need to find the time to change my rotors and pads. All the darn OT were working I have just enough time now to mow the yard and rest on the weekend.
gmduramax
Shits broke
Jun 12, 2008
4,073
249
Nor cal
First drive and it takes less pedal pressure to stop the truck and to activate the ABS. The truck stopped from 60-0mph in 137 feet. 16 more than the stock brakes. I'm going to bed in the pads more to ensure they are working 100% and I'm also going to make sure the pads are moving freely inside the caliper.
gmduramax
Shits broke
Jun 12, 2008
4,073
249
Nor cal
Bedded in the rotors some more and it's down to 116 feet. Going to check the pads tomorrow to make sure they are sliding properly.
