100 PSI Boost into ECM feed.
Fingers
Village Idiot
1,718
96
White Oak, PA
Could be the tables can't handle the bigger number. That is, the boost values are probably out of range for tables that use boost as an index.
You would be safer to do a fake out by scaling it by 1/3. That is 100 PSI on the boost sensor registers as 30 for instance. That would at least assure yourself that you do not over run the index limits of the tables.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Here's the Honeywell P/N, and a picture of it with a MAP sensor end soldered onto it.
The Honeywell unit will read .5v at atmospheric, and 4.5v at 100psig. You will want to verify this yourself jic. You will scale B0202 to match this. Don't worry about the 72.5psi cap, it will have no effect.
I will get back to testing this more, but for now I got to move to other stuff.
Cougar281
1,830
267
St Louis, MO
Is that MLH100PGL05A? I might be blind, but I'm having a hard time reading the whole number.
