100 PSI Boost into ECM feed.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
I am bringing this thread to the top because I want to thank all involved here. I wish I had reread this sooner, since I will now be logging full boost and DP using my isspro sensors! :thumb:
So you used the 67 dollar sensor and your now able to log boost all the way to 100psi in the Ecm? Is that correct
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I knew that the Isspro sensors were 5v sensors, that's what lured me to them in addition to the simple wiring and logging software. I can log using isspro's software already, but I would have to have the screens side by side and the log was not on the same screen. I guess I had a brain fart until rereading this and finally saying, "wtf am I doing?!"
clrussell
pro-procrastinator
Sep 23, 2013
5,948
409
Back from the dead for info..
Has anyone figured out if this will work with an insite? Or do they use their own scaling and not raw data?
schulte
Jul 31, 2010
449
CT
I did this in my truck with a $35 Amazon 0-100psi 0-5v sensor; works perfectly in my LLY...
Next step is to do it for drive pressure as well so I can log that in EFILive to adjust my wastegate regulator.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,781
Des Moines, Iowa
What Sending unit did you end up using? I have been thinking on doing this, but it seem there hasn't been a lot of feed back on it.
EDIT
Is this the sensor you are referring to?
http://www.amazon.com/PartsSquare-P...7807748&sr=8-16&keywords=0-100psi+0-5v+sensor
