100 PSI Boost into ECM feed.
ZR1160
TT Dmax Junkie
Jan 12, 2007
221
Eastern Canada
One toy I always wanted was the TS Performance MPD HUD, but it only reads boost from the ECM, I wonder would there be make it work with this sensor?????? nice and stealthy!
IdahoRob
Jun 5, 2007
1,151
I had one, never did get it to read anything but boost(max 38) and EGT, no rail pressure or rpm. Customer service sucked.
Nice Pat, this is very useful for aftermarket charger trucks.
ZR1160
TT Dmax Junkie
Jan 12, 2007
221
Eastern Canada
That's too bad....I really rather have HUD over a gauge pod.......
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
I'm wondering now about re-tapping one of my stock EGT probes pre-turbo and peeling the wiring out of the harness that runs down the framerail to change sensor location.....Hmmm, i'm glad you posted this!!!
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Fingers
Village Idiot
1,718
96
White Oak, PA
That is a circuit I would like to see Pat......
You need to energize the circuit with a constant current source while factoring in the influence of your measurement equipment.
Use the chip. It does it all in one package for you.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Fingers
Village Idiot
1,718
96
White Oak, PA
That chip looks like a good resource, the only issue I can see, is that it will read 1v at 212F, and 10v at 1832F, so it needs a resister to divide the voltage in half. It's used with standard thermocouples though, not the LMM style.
Voltage divider. So two resistors in series. Supply voltage to the outside of two resistors then tapping between the two for the divided voltage. Two 1Meg resistors would work well.
racinmike77
Sep 14, 2008
1,029
MD
pat do you have a PN so that we may purchase this or have you considered selling it yourself?? I for one am interested in this.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
I should be done testing this week, and if it works, I'll provide a link to the sensor. Kinda sucks since I've spent a few hundred testing different models, but I've given up selling anything for the most part. It cost me more to sell stuff than any profits I get, with the exception of EFILive and tuning.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Here is the Schematic for a LLY EGR you could also run direct from the ECM for a cleaner install....But I cant remember the pin #s
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
I found this tonight slumming on gasser trash boards.
Zero to 100 psi Honeywell sensors #4040PC100G40
-these have a larger male 1/4NPT fitting end.
-voltage outputs are as follows---tested at 4200' elevation (12.65psia)-----so they may be slightly different at lower altitudes:
PSI--------voltage
2-----------.68volts
10-----------.93
20---------1.33
30---------1.73
40---------2.13
50---------2.52
60---------2.93
70---------3.32
80---------3.74
90---------4.13
100--------4.53
Found here http://www.ryanbrownracing.com/Bill_Jones_Page_29.html
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
So does anyone know what are pigtails are for the factory boost sensor? Or where to find this info?
The link John posted has a lot of options:)
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Sorry folk, I was dinking with other stuff.
I'll post up this weekend. I have to find the invoice for the sensor.
The color codes in my earlier post are correct.
