1/4 mile discussion and time slips post here!
CaptPhil
1,012
Delaware
Look at 20,21,22 The Duraflite is better suited for the job but if a truck 60's decent and you have the truck figured out the Allison can do just fine. A 2nd gear start is a simple fix for the short 1-2 shift.
True, but a second gear start with this power will eat converters won't it?
15,681
233
5th and 6th gear in the Allison cause a lot of drag and load on the engine. The front rotating assembly needs a lot of help as it drags power down as well.
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
No leave these posts in, it's a good discussion and that's why I post the extra information,. CaptPhil I need the rest of the info on your truck, it's weight with driver and who tunes it. I think you tune it or so I'm told. :thumb:
15,681
233
You're right Ken. All the posts stay.
CaptPhil
1,012
Delaware
Don't know the weight. I tune it.
Awenta
4,090
CT
picture.php
Don't know anything about the pass or your truck, post up a time slip, best et and best mph and the date/s, the info on your truck, type, weight, tranny if not an Allison and who tunes it and I'll post it up.
Probably missed it. Just need the rest of the info
joegorby
Apr 12, 2012
98
41
Washington Pa
2010 lmm GMC 2500 ccsb, Allison trans, 6750 lbs. and PPEI
Subman
Old Geezer
Jun 27, 2008
3,233
80
1.Banks Dragster 7.170 @ 181.08 (4-30-09) - 2290 lbs, Liberty XT5/Molinari Clutch - BANKS
2.NGM Diesel Prostock 7.44 @ 187.55 (6-1-13) - 2800 lbs, turbo400 - Johnboy
3.J.Dean's Dragster 7.64 (6-8-13) @ 170.41 (10-13-12) - 2100 lbs, LBZ, powerglide - Stingpuller.
4.Banks Sidewinder Type-D Prostock 7.723 @ 179.23 (3-29-08) - Liberty XT5/Bruno - BANKS
5.NX dragster 7.829 @ 172.08 (6-11-11) - LBZ, Powerglide - Johnboy
6.Batmobile prostock 8.076 (7-11-15) @ 177.23 (4-11-15) - 2700 - LBZ,Bruno/Lenco - Milliken
7.John Sleath, (UK) S-10 Prostock 8.469 @ 166 (7-25-15) - 3350 - LB7, 4L80E - Sleath
8.bcdeutch731 C-10 8.621 @ 161.25 (7-11-15) - 4610 lbs, LLY, T-400, 2x4 - DP
9.Dirtymax prostock 8.63 (6-16-12) @ 158.23 (5-19-12) - 3268 lbs, LB7, Lenco - ATP
10.RPM Motorsports 73 Nova 9.150 (10-26-14) @ 155.49(6-6-15) - 3460 lbs, LBZ XP 5 Glide, ATP
11.NX Mustang 9.216 @ 154.5 (9-18-10) 3600 lbs, LB7, 4L80 - Johnboy
12.N20 Dmax 9.24 @ 151.6 (10-20-13) 5900 lbs - LB7, Duraflite - TTS
13.Max'd Out 9.360 (10-15-11) @ 152.37 (5-30-15) - 6050 lbs, LBZ, Duraflite - ATP
14.Trippplemax #1 9.370 (3-22-14) @150.20 (5-30-15) - 6005 lbs, LBZ Stroker, Durflite - C. Buhidar
15.K Douglas C-10 9.393 @ 147.46 (10-4-14) - 3100 lbs, LBZ - 2x4 - G&J
16.Trippplemax #2 9.459 @ 146.45 (8-8-15) - 5950 lbs, LBZ, stroker, Duraflite, C. Buhidar
17.Overkill 9.50 (6-23-12) @ 153.30 (7-29-13) - 5950 lbs, LB7 - Dmitri
18.Merchant's Sandrail 9.62 @ 138.90 (6-27-15) - 2000 lbs, LBZ - Dmax Tuner
19.Brett Williams 9.688 @ 147.10 (6-14-14)- Lb7 - Starlite
20.Mad Max/Hell Camino prostock 9.68 @ 149.1 (8-10-13) -3600 Lbs, LBZ, duraflite- ATP
21.Mike Graves 9.735 @ 145.17 (10-24-14) - 6920 lbs, LB7- MOONSHINE
22.cafryer 9.769 @ 145.02 (8-16-14) - 6500 lbs, LB7 - Duraflite- Starlite
23.Dallas@Suncoast 9.778 (6-11-11) @ 139.33 (5-18-12) - 6300 Lbs, LBZ, Duraflite
24.Rick Fletes/RPM MotorSports 9.78 (8-17-13) @ 142.4 (6-29-13) - 4530 lbs, LBZ Chevelle, XP-5 PG -ATP
25.Extreme Prejudice 9.87 (7-10-10) @ 146.13 (5-15-10) - LB7 - EPR
26.Orange Crush 9.875 @ 139.41 -(9-25-07) - LB7, 2x4 - TTS
27.Mika (FIN) 9.897 (8-29-10) @ 138.70 (8-14-10) - 7160 lbs, LB7, Duraflite - BOBO
28.Camomax 9.91 (2-25-12) @ 139.36 (11-19-11) - 6150 lbs LB7 - Duraflite, ATP
29.Dan PPE 9.947 @ 142.04 (11-1-14) -6200- LLY - PPE
30.Duramini2001 9.994 (8-13-11) @ 138.566 (5-15-10) - 6700 lbs, LB7 - Dmitri
31.SmoknDmax05 10.001 @ 135.58 (8-12-15) - 6400 lbs, LLY - Fleece
32.Misery 10.01 @ 144.52 (10-4-14) - 6000 lbs, LB7 - PPEI
33.estelly 10.13 (5-18-12), 140.05 (4-15-12)- 6140 lbs, LMM - PPEI
34.Jim Jones 10.148 @ 140.52 (10-13-12) - 6150 lbs, LB7 - ATP
35.OSUBeaver 10.184 (8-13-11) @ 134.59 (5-21-11) -5997 lbs, LB7, Duraflite - ATP
36.MorePower 10.271 @ 133.39 (7-13-13) - 6820 lbs, LB7 - DP
37.TDS Miami Colorado 10.281 @ 137.72 (4-25-15) - 4550 lbs, LBZ - Duramax Tuner
38.NolanW 10.285 @ 133.15 (8-11-12) - Duraflite - ATP
39.Sweetdiesel 10.286 @ 144.09 (9-3-10) - 5700 lbs, LB7 - Simon
40.J Hyatt 10.332 @ 141.13 (8-15-15) - ? lbs, LB7 - ATP
41.Custom Auto shop truck 10.34 @ 140 (8-25-12) - LB7 - Custom Auto
42.Nasty Girl 10.355 @ 131.11 (7-13-08) - LB7 - MOONSHINE
43.Sickdiesel 10.429 @ 134.00 (4-6-14) - 6450 lbs, LBZ - ATP
44.BadDmax 10.438 @ 132.31 (7-10-09) - LB7 - MOONSHINE
45.MaxPowerLB7 10.47 @ 132.0 (3-11-11) - 6460 lbs, LB7 -Trent
46.Stingpuller 10.47 @ 131.75 (7-18-09) - 6000lbs, LBZ - Stingpuller
47.Alligator Performance 10.490 @ 132.78 (10-27-13) LBZ - PPEI
48.UDP 10.506 @ 137.71 (6-1-12) 6700 lbs, LB7 - UDP-mike
49.Trojan366 10.522 @ 132.62 (9-13-14) - 6860, LLY - DP
50.Dmax Tuner 10.546 @ 131.15 (9-17-14) - 5500 lbs, LB7 - Dmax Tuner
51.Hondarider 552 10.578 @ 133.88(4-6-14) - 5400 lbs, LB7- PPEI
52.Casper 10.59 @ 128 (10-26-07) - 6420 lbs, LLY - McRat
53.BLKLMM 10.625 @ 134.34 (3-22-14) - 7000, LMM - PPEI
54.White Devil 10.672 @ 132.62 (4-24-15) - ?, LLY - CaptPhil
55.GMtech07 10.682 @ 129.59 (4-28-14) - 6300 lbs, LB7 - PPEI
56.White Out 10.703 @ 130.39 (8-27-10) - 6650 lbs, LBZ - ATP
57.Rhall 10.72 @ 128.0 (8-15-09) - LB7 - ATP
58.02Bigstrokin 10.732 @ 129.59 (9-8-10) - LB7 - MOONSHINE
59.Jpowel29 10.778 @ 125.56 (10-25-14) - LBZ- JPowel
60.Othrgrl 10.74 @ 135.94 (6-19-10) -6800 lbs, LLY - DA
61.straightpiperoar 10.78 @ 127.37 (6-15-12) - LBZ - ATP
62.Big Bird 10.82 (10-10-10) @ 129 (8-14-10) - 7200 lbs, LB7
63.NLDP 10.85 @ 123.35 (6-24-06) - LB7 - TTS
64.Mike Diesel 10.867 @ 131.30 (8-14-15) - 7000 lbs, LLY - Starlite
65.The Dumpster Van 10.868 @ 124.82 (4-12-14) - 5320 lbs, LBZ - 4L85E - 2x4 - JoshH
66.Bluessmax 10.878 @ 128.31 (7-21-12) - 5650 lbs, LBZ - 2x4 - PPEI
67.Maxpower91 [email protected] (10-27 -12) - 6900 lbs, LB7- Duramaxtuner
68.White Lightning 10.96(5-18-13) @ 127.76 (6-8-13) - 5850 lbs, LBZ- DP
69.J&R Auto Chev 10.973 (8-14-10) @ 126.15 - J&R
70.Utahski 10.979 @ 125.55 (10-5-12) 6900 lbs, LLY - EPR
71.Joegorby 10.984 @ 125.94 (8-14-15) 6750 lbs, LMM - PPEI
__________________
9,905
151
I never thought in a million years that Casper would drop out of the top 50... Just shows the progress of the Duramax:thumb:
Almost 8 years in the top 50.
Orange Crush is the only one that has been there longer.
SmokeShow
6,818
Lawrenceburg, KY
I thought kat said McRat & Robert were putting Casper back together for a resurgence this year? But nada thus far. I hate that life got in the way of their evolvement on at least this forum & in racing. :eek:
