Well I'm not going to declare victory on the mount adapters until I get the bolt clearance issue figured out and get the trans corssmember finished, but from just checking around and looking at other clearances I think I'm close. No secrets here!
I did some hand calcs and assuming that the motor mounts mount to the block at a 45 degree angle, using 1/4" plate I added .707 inches to the width, and therefore .707 inches to the height of the engine by running 1/4" adapters on both sides. Durry SS said that his oil pan lip actually sits below that bolt I'm having issues with, but he ran a little thinner plate and said that his engine actually sits lower than the gasser did by 1/8". I'm going to try to grind the rest of the hex head off that bolt and see what happens. If that doesn't work, I may try to start trimming down part of the rubber bushing inside the front diff mounting bracket to see if I can get the head of the bolt to recess inside of it. That bolt has a small hex head on the opposite tip as well, so I don't think it's critical to have anything on the engine side that can be grabbed with a wrench.
Here's some more pics I took this morning.
Passenger side mount installed
Driver side mount installed.
Here's a couple showing the oil pan and center link level with each other.
Radiator hose clears steering box
