I've got a project going right now to put the complete drivetrain, interior, and electrical from an 05 donor into a 99 half ton RCSB.
The current plan is to do a 2" body lift to clear the LLY cooling stack, run the 1/2 ton 8.25 front axle, and do a 9.5 SF rear end.
I bought the 99 back at the end of Feb, started tearing it down at the beginning of March, and picked up a LLY donor about 2 weeks ago.
Here's the progress to date:
99 loaded up for the ride home
Teardown started
Body removed. This took about 4 hours...wish I had a lift!!
Chassis rolled out from under the body
Donor made it home after a 35 hour round trip from Denver to Houston. If I never get the chance to do that trip again, that's ok!
05 dash frame installed in the 99
Starting to look like an 05 LT interior
XM and Onstar antennas mounted to the 99 cab roof
The overhead temp sensor for the auto climate controls doesn't fit under the 99 headliner. Not a big deal, the 99 headliner is pretty nasty anyway. When I'm done with the rest of the truck I'm going to look for a headliner and a few other trim pieces from a reg cab truck with the auto climate controls. This is the only part that didn't go together smoothly....
...and the 99 LS has been converted to a 05 LT interior!!
Here's a preview of my EXCITED face when this project is complete B)
That's where it sits right now. I have the front end of the donor LLY torn down in my driveway, hoping to be able to pull the driveline by this weekend. I want to power wash the 99 frame and see if I can clean it up a bit, swap fuel tank and chassis wiring, then it'll be about time to get that LLY/Allison to it's new home in the 1500 frame! More to come!
Teardown started
