04 trucks?
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
My gaskets made it to 137,000 miles. Put efi on and 2 days later is started spitting coolant. Since then, I have had zero issues with it. Have dynoed over 750hp on the stock motor countless times over the last year, my track times show closer to 700hp though...you get the idea. My truck never comes off the big tune and i beat the snot out of it everytime I drive it.
I love my lly and would recommend them over any other year dmax anyday.
CarolinaHD
969
NC
Wow, I've never heard anyone still running original injectors on a LB7? That's insane!
Just picked up a 271000 mile 2003 lb7 with original injectors and head gaskets. I think the only thing made it go this far was the fact it was never tuned.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Damn dude you just got really bad luck. I'm at 150k on original set
I didn't buy it until it had 162K miles. I kick myself for changing the set that was in it with 130K miles on them because there was nothing wrong with them. I thought I was doing good by changing them out while it was out of the truck doing the head gaskets during my swap(passenger side was seeping down the back of the block), what a mistake that was. 2nd mistake was trying to save money and putting in pensacola injectors. Learned the hard way about trying to save a buck.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Theres plenty of LB7's out there with that many miles that have been tuned since early on in life. They are out there, but you primarily only hear about problems, not happy drivers using there trucks. And my head gaskets weren't leaking any compression out, but instead had a small coolant seep down the back of the block on the passenger side.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
So the LLY 04.5 injectors are outside the valve covers right? No major injector problems like the LB7s?
Yes they're outside the valve covers. Do some searches and you will find LLY's are proving to almost as problematic with injectors as LB7's were. Most shops will tell you flat out they are doing more LLY's than LB7's anymore. And I woudl MUCH rather do LB7 injectors than deal with changing out LLY's.
CaptPhil
1,012
Delaware
That is the first time I have ever heard someone say they would rather change lb7 injectors than any other year.
onebaddmaxxx
1,212
Cecil County Md
Your on some good shit if you'd rather do lb7 injectors lol. Lly are more problematic now because a lot of the lb7s have been taken care of. And they are being rebuilt with better parts. My lly has 215k and may just be starting to show a few injectors getting out of spec. I can deal with that.
I had to do head gaskets though.
02greysixer
1,829
North Central FL
If I'm on the clock I'd rather do lb7 :D
We still do more lb7 sets of injectors than any other generation. Probably more than all other generations combined.
1,952
You feeling ok, Ferm? :confused:
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
Goodyear, AZ
There are also more lb7's then any other generation, 4 years worth. And they are the oldest.
But now compare an lb7 to an lml I think lb7 injectors are way cheaper then deletes and upkeep on the terribly built lml
In the short time I worked for GM as a tech I did just as many lly/lbz injectors as I did lb7
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Ferm, I think that were seeing LLY's because of there age, more miles and hours now. Next will be the LBZ's, then the LMM's etc etc.
I will leave the changing LB7's over LLY's alone...:D
Awenta
4,090
CT
Yeah as they get older more things will break. Injectors are normal wear + luck.
Aug 3, 2013
898
Arizona
The've been making lml's longer than lb7s now man!
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,215
365
At Da Beach
Yeah and by the time you do full deletes and cp3 conversion just to prevent it from costing you an arm and a leg your in it for more then the price of lb7 injectors and all that just to keep it reliable.
No need for cp3 conversion after mid 13. Bosch redesigned the metering valve, which came apart in the previous generations and contaminated the fuel with metal particles. Plus, how many fords you hear about having issues? It's bc ford added a 55 to 110 psi lift pump, I've had an Airdog since 2,000 miles setup with a cummins spring kit. If you feed the cp4 it will live just as long as a cp3, I know of several LML's approaching 600,000 miles and I know of one over 800,000 on original injectors and pump. I've never heard of any of the previous generations going this far without injectors or a pump replacement...
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Feeling fine. At least with LB7's you don't have to deal with a friggen injector that's a mile long trying to turn it just right to drop down in the back cylinders, you still have to take all the crap off the top of the engine to do LLY injectors, you have TONS of crap that likes to fall down into the holes when you pull them out, rusted hold down bolts for the injectors, and a few others. I know I'm not alone in this feeling as well. I've done 2 sets of LLY's, and do not care to do another set. And I know of 2 LBZ's right now that need injectors because of P0087, but they don't think LBZ injectors fail so they won't do them. This whole only LB7 injectors fail is getting old. They ALL can fail. At least LB7 injectors are cheaper to buy when they do go. I've seen what a set of LLY's and newer ones cost, NO THANK YOU!
