I recently started pulling a 6,000 lb boat/trailer combo and my ZF6 is getting a lot hotter than in the past. Hot enough, I believe, to cause clutch disengagement issues after a long day of hauling the boat. My 02 3500 CC is converted to a class C motor home and when fully loaded the gross vehicle weight is around 12,000 lb. So now with the boat/trailer in tow its no wonder the transmission is heating up. When cool the ZF6 shifts fine.
I want to add some external cooling to the transmission fluid to help with the heat build up issues. I have seen the Fast Coolers PTO cover add-on sumps that achieve up to 2 additional quarts of fluid to the tranny. I have also seen the TDS PTO covers which have threaded ports, supposedly to allow fluid to be pumped from the transmission through a transmission cooling radiator. And years ago some one on this board even offered a complete kit for a circulating external cooler for the ZF6. But I can't find that person now, so I'm hoping folks on this forum can help point me in the right direction with this cooling need I have. Thanks
