Where do you guys turn your wrenches?
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
Mitch, We've been lookin at buyin a small farm and building a shop. I really haven't been involved in the prices but It is water (basically free) so either way I'm sure you will get your money back really quick
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Well, the Ratcave is almost 100%. I took a quick video just now, but it's too big to post. I guess I should have taken pictures.
By cramming everything from the old McRat Racing building into it, it's pretty disorganized.
Only the upstairs is A/C'd but it's well insulated, doesn't get very hot or cold, we only see 30-110°F temp ranges here.
It has two bays, an RV bay that is 14 x 40 x 19 tall, and a car bay that is 30' x 30' x 10'. It has a toilet, sink, and on-demand hot water. The upstairs is 14' x 30' x 8' and is both a workshop and a home theater.
There are NO Christmas decorations, lawnmowers, yard tools, kids bicycles, antiques, seldom used kitchen appliances, etc, in it. If it doesn't burn fossil fuels it doesn't belong in there. :D
MadMaxx61
Devilmaxx
Oct 13, 2008
5,458
Windsor, Ont, Canada
but lawnmowers burn fossil fuels well the good ones lol
durallymax
Apr 26, 2008
2,756
Under The Hood
I don't have one and can't really afford to build one either. Maybe can later in the year.
How much additional cost to the concrete floor does it add to have the radiant floor heat? How much is a heater for that setup versus a conventional unit?
C-ya
concrete price will be the same, a seperate company will lay the radiant heat. as for cost i dont know,.
Over time it takes less energy to heat it.
But make sure you plan everything out first like where car lifts will go and such, if you dont then you may ne in for trouble because once that tubes in the floor your done drilling holes in it.
9,903
149
The water is supposed to circulate IN the floor not on top of it:thumb:
But at least you do have the expensive part out of the way, or at least a big chunk of the cost, concrete aint cheap these days.
Your not kidding. The finished product framed and roofed to lock-up is going to be about $40 000 CDN.
The floor was a 1/3 of that cost!!
9,903
149
My shop...Gets a little drafty at times:thumb:
That's a nice little dumptruck!!
The place I get paid to wrench sometimes gets a little drafty as well!!:happy2:
Jarasic
Diesel Enthusiast
Jul 2, 2009
49
Chilliwack BC, Canada
Man Cave
18'X20' attached garage, a 20' truck and two quads made this head gasket job on my room mates LLY last weekend a bit tight. Gotter done though. Took a couple pictures showing how tight it was when we had to close the garage door and grab a couple hours sleep.
firehawkclone
Roadracer
Nov 20, 2009
23
Bakersfield Ca
I'm never home so its always a mess. Im always out in some oil/geo field working!
The best part:thumb:
1,623
Nice shop Scott. What exactly do you do? Own your own business or do repair on the side?
If I ever got a lift, Id be the happiest man on the planet. No lie. Im getting too old to lay on the ground. It sucks.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
I work for a naturl gas company,Customer service field.I go on gas leaks,change meters,turn ons turn offs.I started fliping cars on the side mostly GMs started in the front 3 car with a floor jack a motor hoist and jackstands,bought a tow dolly and started chasing down 4 to 500 dollar cars with straight bodys that needed motors or transmissions and went to work.Paid for most all my garage and tools the lift.I couldnt do alot of floor work anymore,back is bad.The lift is more afordable then you might think but watch the price of steel and fuel i had got a price on the lift and saved and a year later when fuel was 5 a gallon and steel was high they wanted 2375 for the lift and 450 to deliver to so i needed more money.A little later i flipped a couple more cars and went to buy and this time the lift was 1875 and it was 245 to deliever becasue fuel and steel was low so know when to strike on the lift for the 1875 that lift was been priceless and ive had a CClb dually on it no problem.I need to update because these videos are old and now i have a sand blaster,parts washer,2000lbs trans jack and more.The set up and the planning is everything before you start once you have a good plan then act on it if you think as you go and start blind there will be a ton of things you will wish you did and it may be to late.
1,623
Currently, the only thing I'd like to do to my "shop" is install an overhead door in the front instead of using the one on the side. While good for the lawn tractor, it is very difficult to get a truck in the way its set up.
Eh, it's all a moot point til spring. I hate working in cold weather unless I absolutely have to.
DuramaxPowered
Pushing my luck....
Jan 27, 2008
791
41
Monroe, MI
I built a 36x54 pole barn with 16' walls 3 years ago. Radiant floor heat, a bathroom, and 10,000 LB lift get the job done. Wasn't cheap to build, but it was worth it for sure. I would like to get a few machines like a mill, lathe, and cnc plasma table.
07keo02
Oct 5, 2011
399
Phoenix, AZ
No shop for me, definitely on my want list though along with a thousand other expensive things. For now, I keep the garage organized enough to fit the duramax in it if I need to work on something. I just wired in a 220 outlet the other day to run my new 30 amp electric heater up in the left corner. Its not much but with the tools available and a compressor I can get alot done, If I end up staying here another year I will insulate and wall mount an a/c as well.
yellowchevy
1,913
59
Louisburg, KS for now
You guys have some pretty nice garages/shops to work in. Every time I move my work area gets smaller, haha
My Dad's shop is 42' x 72' with one 10' x 10' door and one 16' x 20' (if I remember right). Built it out of a building we tore down for a new shop out at the farm years ago.
When I moved to Illinois my garage was roughly 24' x 30'.
The place I rented in KC had a 18' x 24' garage, small but I made it work.
Now all I have is the back yard :roflmao:. One of these days I would like to have a shop again.
No matter where I move I always find a way to do what I really enjoy, working/building things; thats what matters.
Yellowchevy
