What sxe? On lbz?
Brabham 64
May 26, 2014
79
What has everyone been running for a sxe on the lbz? Stock everything for now. I typically tow my car hauler with anything from a dodge neon to a Cummins mega cab. And I plan to get a 25-40' 5ther. Upgrades will happen as needed. But 369? 366? 364? I'm typically at the 4000-6000' elevation also what size housing? I have a chance to pick up a bd pedestal with a t3-t4 adapter for cheap and that is why I'm looking for opinions.
clrussell
pro-procrastinator
Sep 23, 2013
5,909
364
I don't really like the variable vane. Idk why exactly but I don't
Well if the truck is 100% stock now your pissing in the wind putting a fixed vane on it.. Do some good tuning and you'll like the variable better. Esp towing
Brabham 64
May 26, 2014
79
I had efi live on my lly for a while and it was good but idk I just like how a fixed vane runs
S Phinney
4,011
Quncy, Fl
If you want to switch go with a 364 or 366 in the sxe turbo. On a stock lbz at sea level the 366 runs really well. Tows really well too. It would need a tranny to take advantage of the extra capabilities.
yellowchevy
1,904
53
Louisburg, KS for now
At your elevation and you tow I'd do twins hands down. I'd also build your tranny before doing anything to your turbo.
If you HAVE to have an sxe I'd do a 364/68 to keep good spool up and get more power.
Also, run away from that BD pedestal, in their stock form their a piece of shit.
Yellowchevy
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
If you have a stock transmission you haven't even started to tap into the potential of the stock turbo. Build your trans and get good tuning, then see whether or not the VGT is the problem.
Brabham 64
May 26, 2014
79
The vgt s not a problem I'm just not a fan. I planned on porting the bd pedestal if I got it. Or atleast opening it up the best I could. I don't need an sxe. I'd really like to spend the extra $ and get the fleece 463
4,953
you start going over a 364 fixed vane and you wont like pulling any 25-40ft up in flagstaff, Allen. and if you dont have a built trans to handle extra fuel to get the bigger charger to light like it can, it will compound your issue
Brabham 64
May 26, 2014
79
Yeah I will need to go see mike before the turbo gets changed. I'm just looking at gathering parts.
4,953
10-4. personally, stay 300 housing and at most, a 366sxe. if you dont go sxe, id stay in the 364 or smaller range. Nate ran that box stock 366 and he didnt like towing much with it. hes going a twin style kit like mine now.
284
Disagree..
362/364 sxe have enough air for 600+ HP and work well with stock/mild tow tune.
I'm not running any more fuel with the 4088 than I was with stock VVT..
VVT made 413 with 16" steel wheels
4088 made 396 with 19.5 steel wheels
225/70/19.5 are about 50# heavier than 235/85/16 setup.
Only things I miss about deleting VVT is turbo brake and quicker warm ups due to closing the vanes when cold.
I had no issues with my 4088(63.5mm) at upwards of 7000' last weekend on a trip to Idaho..
3,681
236
I guess it all depends on your standards, too. I didn't have issues with my S371 (71mm) camping over 7000' here in Idaho a couple weeks back.
No issues, but it was laggy as balls :spit:
284
I'm sure it was slower than at the ~1100' I live at... But not slow enough to catch my attention, that I had to change my driving habits towing 14,000lbs
I was above 3,500' from Wall south Dakota to sandpoint ID and back easy 2000miles
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,033
245
At Da Beach
I would build your trans first and then add some power. Stock turbo built trans lbz was the funnest duramax I've had.
I would agree. That's why I've left my LML basically alone, tune plus a few other odds and ends. :D It's still super fun to drive, pulls incredibly and it's more reliable than a stock one...:angel:
