What Size Injectors
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
Just 2yrs of reading this forum and putting up with shit from guys like you;)
3yrs of calling shops across the nation talking to builders, and
Driving and building my own truck for 3yrs now...yeah, I know that's not much
Why Brian? Was there an untruth in what I said?
My summers are about as cold as your winter...when's the last time you were in sub zero temperatures? Desert boy...
You also made somewhere around 1000whp on stock manifolds and cam etc etc and don't seem to care if/when shit breaks...not exactly what most are willing or trying to do
Thanks for proving my point :thumb: untill you have personal experience on stuff your comments are just as true as anyone else's. anybody can read for years, untill they have the backing to say "go bigger" your posts are just saying "I don't know, I'm just here to post"
I was in sub zero temperatures last week. I haven't broken anything yet at 1k Hp, but thanks for keeping tabs on me, I feel special.
4,975
Only thing I've dicked with for cold starts is the timing table. It was adding too much when cold and rattling like a sob till it warmed up to the switching point.
Being I high elevation and cold, it's gunna be tricky. It's gunna take some time with any tuner to dial in that setup no matter what size injectors, specially if the tuner is not local so don't expect it to be a quick thing. I wouldn't be too worried about injector size for the cold, it's won't be as much of an issue as tuning will be and compression ratio. It's gunna smoke when that cold regardless though I would bet.
andy-stevenson
Jul 7, 2013
838
Ya, no doubt it will smoke; stock injectors won't even clean up at -40*.
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Altitude is definitely an issue. Makes a big difference. Go up to 6-8000' and find out.
I wasn't saying altitude wasn't a key factor at all, if you read what I said, I was saying I don't believe it would be as big of an issue in the cold as it would be when it's warm cuz colder air is typically more dense and oxygen rich. I also said that that was just speculation
:D
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
:D
But temperature aside air at high elevation is less dense.
Hot COCOAL
Jun 9, 2012
4,433
I didn't say anything different than you??? Other than to use a larger fuel supply(12mm cp3/duals)
Also, I said to use 16.5 C/R to help with tuning and running at altitude...
Again, was anything I said inaccurate?
The only reason I figured to bigger on the primary was cuz some guys twin the stock turbo with the 483 and I think a 485 would be more appropriate with the 72
And yes that is just my speculation based off reading, not personal experience, making that comment only in turn spurs more comments and only helps out the op in the long run :)
Utahski
Oct 20, 2008
546
Northern Utah
:D
You have to comment on everything. Instead of speculating so much, better to keep quiet unless you know.
Hot COCOAL
Jun 9, 2012
4,433
I hardly comment on anything anymore, and I'm on the forum every day...
Some of you just dont want to acknowledge I've actually learned a thing or two and would rather be brash than accepting
Cheers
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
0 degree cold start with my 30% over injectors. Hazes like crazy, didn't really care that it hazed cold because it doesn't haze one bit when warm or in the summer....Plus they are industrial nozzles, so who knows if that has anything to do with it.
gmduramax
Shits broke
Jun 12, 2008
4,046
227
Nor cal
Cheers
If you haven't done it. You don't know. I don't give a **** what you've read. Shut the **** up.
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,774
Des Moines, Iowa
This is my truck everday under about 35. Quality injectors and live tuning is the key.
Utahski
Oct 20, 2008
546
Northern Utah
Cheers
So a smiley face sticker on your forehead. And two demerits for brash speculation.
4,975
My truck in 25+ degrees doesn't haze hardly at all. Only when it's colder than 20 degrees or so.
My truck hazed like that with stock injectors/stock motor on first start up in the mornings without plugging the truck in in those types of temps. Did yours not?
