Ways to lower D/P
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
How much time did you have in the header installation?
including removing most of my twins, full exhaust ,ect . i started at 10 pm last night and finished at 4:45am . so 6 hours or so it would have been 1/3-1/2 of that with out the twins . that is using a lift also
the reason the secound turbo had to come off is the headers has to go behind the dipstick tube so you have to slip it in from the top of the motor behind the dipstick tube and lower it in place .
S Phinney
4,011
Quncy, Fl
Let us know how they are after a little more driving. Mine should be in this week. I hope the temps under hood stay in check. I did have them coated inside and out.
TrentNell
Jul 7, 2008
7,543
slc tuah
Also, Trent which rotors are you using? I need some really bad so I stop pushing through the brakes.
I am using the cryogenics , but the rotors wont help much with that but the EBC yellow stuff pads will . also mine was real bad till i replaced the hydro boost , since then with the brakes upgraded and in working order i can boost to 26-28 psi and 2600 rpm with my 1055 converter .
TrentNell
Jul 7, 2008
7,543
slc tuah
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
Nice pipes dude. I would say that your speed sickness is in full swing. I don't know if breaking someone's record would cure it or not. Probably not.:D
TrentNell
Jul 7, 2008
7,543
slc tuah
i was joking about the record deal , just jabbing idahorob :D , i just like going fast and racing , and building the ultimate street Dmax ... its a blast to drive , and am trying to get all my parts so next spring when the motors built all i need is another cp3 then look the f%$# out
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
I have to give it to you Trent, your truck has to be the truck that has undergone the most changes on this iste. You posted a pic of what it looked like when you bought it, and now it's DAMN!!!!!!!!!!!!!!!!!!!!!!!!!!!! I am curious how the pipes work out for yah.
Randy5.0
MAKE IT 3 YDS MF
Sep 7, 2008
292
i was joking about the record deal , just jabbing idahorob :D , i just like going fast, and building the ultimate street Dmax ... its a blast to drive , and am trying to get all my parts so next spring when the motors built all i need is another cp3 then look the f%$# out
I had to laugh man because I've told Rob that I wanted to run an 11.69 @116 when we were talking about goals for my truck. He laughed and said that he wanted to run that too.
You are building the ultimate street Dmax Trent. The only other one I know of like that is Subman's. Standard twins are awesome enough which means you guys are definately sick......... Hey, that might be a good race, you and Subman. :angel:
racinmike77
Sep 14, 2008
1,029
MD
TrentNell
Jul 7, 2008
7,543
slc tuah
Picking up a 16cm stainless turbine housing today , hoping to get it installed tonight . I will post up the D/P results before/after . Nathan found me a deal on a used housing :hug:
TrentNell
Jul 7, 2008
7,543
slc tuah
:physchic: I see someone getting kicked off the track for no roll bar :witch:
we are hoping for an 11.3* run in boise . more air /lower D/P and injectors should do the trick .
finally got a spair motor so game is on to see what she can do on a single CP3 :cool:
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
59
Norco, CA
So are you going to put a bar in?
TrentNell
Jul 7, 2008
7,543
slc tuah
no not yet its still my tow rig :D, we'll run it a few times to see what she can do and i will dial it back after , next year with built motor and dual C's hopefully, i am going to have to do something , should be easy to bump into the 10's with another fueler , but we all know it sounds easier on paper than it actually is in real life :rofl:
