This was Pat's latest Sciece Fair project for Casper. It holds 90 gallons of water and weighs 900 lbs. Worked perfect to keep Casper stable at high speeds. It was built to Pat's spec's by Mitch at Mitch's Customs.
then return it when i'm through
Whats with the gauges? It seems kind of fancy just to hold some water or is there more to it?
It's also acts as a big a$$ radiator
So if you re-designed it to have a completely removable top, you could have a bed-mounted hot tub to relax in after a run....
Lol nice
Doesn't the water do a lot of moving around though?? Or is it so full that there's not much room for it to move???
edit: I like the big radiator tank idea. Definately help keep the truck cool with 90 gallons to pull from.
It has baffles so it wont
Have you guys thought of using Calcium Chloride Kat? It's what they put in farm tractor tires and forklifts for ballast.
Yes but farm tractors and forklifts go slow. fluid in the tires can get out of balance very easily. NOT a good idea
