Water Tank / Ballast
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
59
Norco, CA
This was Pat's latest Sciece Fair project for Casper. It holds 90 gallons of water and weighs 900 lbs. Worked perfect to keep Casper stable at high speeds. It was built to Pat's spec's by Mitch at Mitch's Customs.
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
nice :) when i need to make weight for a pull i get 12 bags of concrete mix and then return it when i'm through
Kat
Aug 2, 2006
17,899
13
59
Norco, CA
So if you re-designed it to have a completely removable top, you could have a bed-mounted hot tub to relax in after a run....:D
Hey why didn't Pat think of that :mad:
Actually there are baffles in there. They might hurt to sit on :eek::rofl:
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
Doesn't the water do a lot of moving around though?? Or is it so full that there's not much room for it to move???
edit: I like the big radiator tank idea. Definately help keep the truck cool with 90 gallons to pull from.
9,903
149
Have you guys thought of using Calcium Chloride Kat? It's what they put in farm tractor tires and forklifts for ballast.
Kat
Aug 2, 2006
17,899
13
59
Norco, CA
Dale, I don't think that would be to good for the engine? :confused:
Opps I guess you meant the tires ;)
03 D-max
Honorary "Tosser"
Apr 29, 2008
3,539
Lowville NY
Yes but farm tractors and forklifts go slow. fluid in the tires can get out of balance very easily. NOT a good idea
BoiseRob
392
You can always turn it into a fuel tank and race in "The Cannonball Run"... LOL
4,830
404
Centrifugal force would balance it out wouldn't it? I think in the tires it would make handling worse since its unstrung weight. Plus Calcium Chloride is $$$$ for a few events since it wouldn't help in the 1/4.
