Torsion bolts removed
andy-stevenson
Jul 7, 2013
838
I've got 8" between the front fender and tire. 10" between the rear fender and tire. That's stock rear end and torsion bar bolts removed. But I also have no engine in right now, I'm not sure how much the engine will drop the front.
motoking_1990
1,950
Terre Haute, IN
There is a lot the plays a role in that. What size tires you have could be different than mine. What's your distance from ground to fender?
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
From my experience removing the t-bar adjustment bolts, from stock ride height will net you about a 2-3" drop...from leveled to nothing is about5- 6"
I removed the LCA bumpstops for another 3/4" too
FWIW, when comparing vehicle to vehicle heights like this over the net, its better to measure center of hub to fender, than FTG height
Hot COCOAL
Jun 9, 2012
4,433
Lol
I've got 8" between my fender and tire too, with my Cognito lift kit and 35's!
1,605
attachment.php
Thats with drivers side completely down, pass side 1/4" up. Nothing done to rear.
motoking_1990
1,950
Terre Haute, IN
Thanks I will remember that for now on. Wheels being larger is another aspect I didn't think about.
motoking_1990
1,950
Terre Haute, IN
Jason, little aggravating to read how some take measurements from the ground to the fender....:rofl:
It's accurate to see how much higher or lower you have made your truck. But to compare to a different truck entirely wouldn't work. I realize that now. Some of us are not as smart as others. That's why we are here. :hug:
motoking_1990
1,950
Terre Haute, IN
I am wanting to run 20x10 -12 offset with 3" shackle and overload off and stock keys with bolts out. Hopefully it doesn't rub.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
It will but only because of the negative wheel offset.
With s 4/6 drop I did zero trimming and don't rub with 305/50/20's but they are +24. With the wheel spacers they are probably only +8 or so now
picture.php
picture.php
clrussell
pro-procrastinator
Sep 23, 2013
5,907
363
Tire size plays a big factor. Trimming will be required. This is dbag exact set up with a 285/55/20 toyo at2 ten ply tire.
It's going to. Alot.
Why so much negativity
motoking_1990
1,950
Terre Haute, IN
Can someone snap a picture of their rear axle block setup on their lowered truck? I need to know which blocks to remove. Mine has 2 blocks. Idk if I need to take out both or one. Thanks
clrussell
pro-procrastinator
Sep 23, 2013
5,907
363
If your truck has any blocks period pull them out. Stock trucks done have blocks.
Yea you'll need new u bolts
