Torklift Superhitch
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
Not cheap, but looks very well built. All 1/4" steel and grade 8 hardware.
15,000lbs Max Trailer
1,500lbs Max Tongue
I hope it fits around the 4" exhaust...should find out this weekend.
attachment.php
attachment.php
attachment.php
attachment.php
WanaDmaxsub
Feb 17, 2007
644
1,500lbs Max Tongue
...these are dead weights. If you use weight distributing the ratings are higher.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Are you going to mount it as far forward as possible?
This will hold your hitch height better when the front lifts. Most organizations are "hook is furthest point back" on the truck. Dunno where Craig got those weirdo rules from. :D
320
unlike a 4x4 were you would want the hitch as close to the rear axle as possible...
on second thought.... i not excatly sure how it would effect a 2wd setup.
part say keep it stock location greater distance between axle and hitch makes it easier to load the rear axle and pull the front up.
other part says move it closer which could possible put more mech load on the axle but would be more tempermental on getting the front end up
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
You want the hitch as close as it legal to the axle for sled pulling.
The higher the hitch point is, the more the truck can lift the front the sled. The closer the hitch is to the axle, the harder it is to push down.
Even for normal towing, you are more stable and can tow heavier before exceed RAWR if you mount forward.
The only downside is turning radius.
Jared Duramax
<---- $$$ Whore!!
Feb 13, 2008
1,052
33
Matthews NC
i would love to see some pictures of that installed. I am now in the market for a new reciever and this one looks real stout.
Let us know how it fits and if it will work with larger exhausts
WanaDmaxsub
Feb 17, 2007
644
...The only downside is turning radius.
Yeap...thanks for the reminder...I need all the turning radius I can get with the TT. Of course an extension would solve that issue also.
I will, with pic's. But I'm not sure if I will get to it this weekend.
WanaDmaxsub
Feb 17, 2007
644
To start off. Here is why I'm replacing the stock hitch. It's bent and pin holes are starting to oval.
attachment.php
attachment.php
attachment.php
attachment.php
Here is a shot of the clearance for the exhaust. It's a "ghetto" 4". I have just over a 1/4" gape. I wanted more but the exhaust wouldn't cooperate...yet! There's lots of room for the exhaust, but you may have to adjust the exhaust pipe to clear the hitch plate.
attachment.php
The cross member is heavy but very balance. It was very easy to lift with the floor jack and line-up with the bolts in the plate.
attachment.php
For the other side I reinstalled the stock bolt (per the instructions). Then swung it out of the way, lined up the cross member with the bolts, pushed it all together and bolted it up.
Note; The instructions say to tighten the bolts to 75 ft lbs. Then re-tighten them to 100 ft lbs. The ribs in the carriage bolts stripped way before I got to 75, more like 50 ft lbs.
attachment.php
attachment.php
One thing I didn't like is the trailer plug. Looks like an after thought to me. Could have been done better/different. There is only 1 bolt, off center, holding it.
attachment.php
attachment.php
All done...except for the stuff I'm going to re-due (Carriage bolts, exhaust and plug) in the near future.
attachment.php
Also...the hitch mounts to the frame using 10 (Grade 8) bolts total. 5 on a side. The cross member bolts to the mounting plates with 8 (Grade 5) bolts. 4 on a side.
The top reciever ended up 3/4" higher than the stock hitch on my truck.
The gape between the back of the cross member and my Mag-Hytec is 30.5". The tire you see in the pic's is for my TT. The spare H2 never did fit under there.
WanaDmaxsub
Feb 17, 2007
644
More than twice as strong:D
The hitch is designed for bed campers. You can get a 4' extension with a 600lb tongue or 6000lb trailer rating (1,200/12000 using weight distribution).
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
hell i need one of these :rofl: after all that pullin mine is starting to bend, im just waiting for it to snap on of these times im hooked and goin down the track.
WanaDmaxsub
Feb 17, 2007
644
The hitch uses a total of 18 bolts.
10 (grade 8) to mount to the frame
and
8 (Grade 5) (carriage) bolts to mount the cross member to the braces. My plan is to replace these with Grade 8.
