Tap shift up and down ohms/resistance
antwon88
Jul 18, 2014
62
hi just wondering if anyone could tell me what ohms/resistance i should be seeing at the two tap shift wires for both up and down shift and also when the switch is neutral (not being touched) a friend and i have been researching for days but no luck yet :confused:
1,623
PM either DuraToTheMax or MaxPF
I think one of them may know those values.
antwon88
Jul 18, 2014
62
hellppppp anyone dont want to fit the wheel until i know for sure iv wired it correctly i should have checked it before getting rid of my last tap shift switch
sbornoe
Jan 13, 2019
up/down switch idle: 6.84k ohms
tap up: 1.87k ohms
tap down: 3.97k ohms
Ben
Hi. Old tread and all of that, but someone still messing with old stuff😅 I am trying to fit Tap S on a LB7 2003, do you have a better explanation on the setup? Which pins to connect on the Red connector on the tcm. I think 2003 and up IB7 are ready for Tap Shift, just need the correct guidance. No BCM, just straight in the Tcm. Don't want to buy the Fleece performance shifter kit, as I am using a different middle mounted shifter with + and -
1,623
Ben hasnt been on the forum since 2019. Unless a miracle happens and he checks back in, you wont get any new info from him.
sbornoe
Jan 13, 2019
Thanks for any answers, I know I am way out here on this. But the Fleece performance tap shifter kit is maybe nothing else than a ohm manipulator to the tcm, and I think I know now the resistance it needs, just where to put the pin in the RED connector. Maybe I am wrong but it make sense, different ohm in TU, TD and in 0 position.
