I knew I could rely on Ben. Freakin genius with these truck's electronics.
Hi. Old tread and all of that, but someone still messing with old stuff I am trying to fit Tap S on a LB7 2003, do you have a better explanation on the setup? Which pins to connect on the Red connector on the tcm. I think 2003 and up IB7 are ready for Tap Shift, just need the correct guidance. No BCM, just straight in the Tcm. Don't want to buy the Fleece performance shifter kit, as I am using a different middle mounted shifter with + and -up/down switch idle: 6.84k ohms
tap up: 1.87k ohms
tap down: 3.97k ohms
Ben
Thanks for any answers, I know I am way out here on this. But the Fleece performance tap shifter kit is maybe nothing else than a ohm manipulator to the tcm, and I think I know now the resistance it needs, just where to put the pin in the RED connector. Maybe I am wrong but it make sense, different ohm in TU, TD and in 0 position.Ben hasnt been on the forum since 2019. Unless a miracle happens and he checks back in, you wont get any new info from him.
