Hey guys I pulled my truck for the first time last year at my local fair and did pretty well. I had a few questions about what I should do this time. My truck is around 500hp an I pulled in 3 low tcc locked once I hit 2 gear. It seems like I pegged 3 gear easily and say there for a while. Somewhere Around the 250 mark my rpms were pulled down drastically. I threw it in neutral around Maby 1500 just because I didn't want it to stall out. I have duratrack tires and they were set to 35 front and 45 back. Leaf springs clamped and suspension stops set at 1 inch.
My questions are I don't think I spun any tires at the end. Should I be trying to spin out so my rpms don't drop so fast and screw me up power wise? Maby raise tire pressure ( I also plan to monitor rail pressure this year)
Should I unlock the converter at the end to help with the rpms?
Will the Allison downshift to second on its own? I have stock TCM tuning. If not would having a tsp shifter benefit me?
Is there any scenario where I let the truck hit 4th gear for more ground speed. I'm guessing not because I know it would just need to down shift
Thanks for any advice.. I only plan to pull once a year for fun fun so I don't have alot of time to trial and error
