I have been running a stock airbox with a LBZ inlet elbow and a TxC CAI for about a year or so now and ran a best ET of 12.82 and a best trap of 107.75mph
In my quest for mid 12's on a stock turbo manual trans truck I decided to run an intake after much research here and on DP "cough cough" anyways it seems the performance minded folk run S&B or Banks so I bought the S&B mainly due to the cost. I bought the LBZ kit to run on my LLY and modded my MAF tables in EFi live so it wouldnt cause problems or throw codes.
The mounting base needs to be modified to add a hole for the rubber attaching gromet in the correct location and I have to cut out some material yet so the bottom hole of the intake can suck from the bottom of the intake box also. The LLY plate is almost solid metal so the intake will only suck air from the fender vents.
The difference in the tubing bends and size is remarkably different but I was optimistic still until I took the truck for a spin.......holy cow did it wake the truck up. Boost is instantaneous and it pulls really really hard thru the rpm range now.
I may try to adapt a Banks scoop to the airbox for some added effect at the track but I am quite happy with this system vs. my modded stock setup. I am going to get some data logs on the street of IAT with the stocker vs. S&B but I think it far outperforms what I had and may get me closer to my goal of 12.50 this season.
