LB7: Runaway Help
02greysixer
1,829
North Central FL
One won't do it but if the other 7 are worn/leaking badly it's possible. Surprised your cp3 is able to build rail to start with an injector leaking that bad
Sent from my SAMSUNG-SM-G870A using Tapatalk
kx500
Dec 17, 2010
Montana
It's a pretty good mist of fuel coming out the hole
Sent from my XT1254 using Tapatalk
Awenta
4,090
CT
Pressure?
Fuel rail pressure. I agree^^ usually if one is dumping so much it's tough to build enough pressure to start
kx500
Dec 17, 2010
Montana
The fuel rail pressure was staying around 4500 to 5529 psi. It's hard to watch when the RPM is racing up
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
any smoke when it does this? black I'm guessing, and you cant watch throttle position yet? did you try disconnect the tps and see what that did. it should start just no rev.
kx500
Dec 17, 2010
Montana
It smokes bad. And a fire ball rips out the exhaust. I have not tried the throttle apps. I have it tour apart waiting for a fpr.
Burn Down
Sep 14, 2008
7,093
Boise Idaho
Did you run the compression test on the cylinder that was leaking fuel? I have had engines try and run away like that when the intake valve drops and takes the tip off the injector, that cylinder starts pumping fuel into the intake and feeds the other cylinders.
kx500
Dec 17, 2010
Montana
The compression in that hole is right on with all the rest.
Awenta
4,090
CT
Why did you get a fpr?
Unplug it and see what it shows
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
What and where did you get these new injectors? That looks exactly like a truck I did for a customer of mine. He supplied the "new injectors". They literally cost $100 a piece and did basically the same thing.
02greysixer
1,829
North Central FL
After seeing that my money is definitely on shit injectors. I bet the smoke smells like raw fuel and burn your eyes? Either have them tested by a Bosch facility or buy Bosch remans and install.
kx500
Dec 17, 2010
Montana
They are Rehman injectors. I wish they would have cost a $100 a piece lol
Awenta
4,090
CT
I agree on injectors. Get them tested.
Did they come with a sheet?
kx500
Dec 17, 2010
Montana
Yes they're on their way out right now. I just wonder what's wrong with him
