LB7: Runaway Help
kx500
Dec 17, 2010
Montana
So I pulled my engine out to do head gasket and studs. I had the heads done and new injectors. I also built a compound setup. My problem is when I go to start it all it wants to do is runaway. The engine had no pipe hooked up just the exhaust side of the two turbos. Where do I start?
kx500
Dec 17, 2010
Montana
Through the exhaust side? Because the cold side of the primary and the secondary wasn't even hooked up
Sent from my XT1254 using Tapatalk
kx500
Dec 17, 2010
Montana
Would a bad fpr or a FICM do this?
Or injectors. Because the key will still kill it
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
do you have both boost pipes off and just running with the bridge open to atmospere? that would isolate the turbo if it is bad and by Hot side he means the boost pipe coming off the outlet of the turbo. look at throttle position with a scanner is it somehow up high? like 50% or so?
kx500
Dec 17, 2010
Montana
Yes the bridge is open to atmosphere. And there is no oil in there. I will check the throttle position
catman3126
Jul 24, 2012
2,636
NE Oregon
yeah I can't imagine it running away from the fuel injectors unless it is getting some type of input. have you let it rev to the governer and does it stop there? On second thought don't do that lol. by the time you realize it wasn't going top stop at the 3500 or so it could be too late to shut it donw before bending push rods.
kx500
Dec 17, 2010
Montana
How else can I check the throttle position? My scan tool does not have that option. And no it does not stop on the governor.
Awenta
4,090
CT
What scan tool. Most of them can see it
kx500
Dec 17, 2010
Montana
The Diablo ones? I thought they could see live data
Yes diablo. All I see on the scan tool is
Engine load, engine coolant temp, map,RPM,speed iat maf ,rail psi, timing , and injector balance
CaptPhil
1,012
Delaware
You dont have a high pressure fuel leak from the cp3 do you? That would spray fuel right into the intakes.
kx500
Dec 17, 2010
Montana
If I unplug my throttle apps. Will the truck start and idle?
kx500
Dec 17, 2010
Montana
Tell me what you think. I pulled all the glow plugs and decided to do a compression check. I'm doing the compression check and I had one hole sitting there just spring out fuel the whole time. Is it a stuck open injector? Would that make it runaway?
