Rings wore out?
4,956
Do a wet compression test (put a squirt of oil down the cylinder, then do a compression test). If it goes up, it's rings related. If nothing changes, do a leak down and listen in the intake or exhaust for air escaping. If you do, you have bad valve/s. If you don't, it's short rod syndrome.
GeorgiaDieselGTO
Wants to drive his truck
May 12, 2010
102
Crossville
If you are seeing blowby out the filler neck it will be ring related valves can cause low compression but not blowby. If I were u I would keep on driving unless its gets bad
