Sorry, I meant after just the oil filter is removed without draining the pan.
Thanks Adam, but I meant after just the filter is removed and the little bit that drains out. Not a full oil change, just a filter change. Is it close to 1 qt or something like that?
Just an FYI, I went out there with a measuring cup. With a little spillage I came up with about 550 mL.
Ive done some filter changes for a few friends and couldnt believe how tight the dealer guys put these on .
I had to cut the can completely off and use a chisle and hammer to get off the base .
I put mine on tight , but that was ridiculous , and not the only one I have seen like that .
