LBZ: Power loss
Jan 28, 2015
961
Ohio
17mm swivel socket for the 3 pedestal boltS. The middle one is a pita. I go in from the pass side. Up pipe bolts are 11mm. 12 point. Then there is two nuts on the back for the oil drain. And two coolant lines on the side. They are also 17mm iirc.
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
Probably take you 2 hours to get it off the first time you do it, but it is not hard. Go slow and be patient.
No offense but I've pulled quite a few stock lbz turbos and I can't pull one in 2 hours.. The up pipe bolts kick my ass every time.
Maybe I'm doing soemthing wrong? Book time on an lbz turbo is like 12 hours..
02greysixer
1,829
North Central FL
I'd love to see this done on a truck that's never been apart with 200k miles. Not just an lbz any Duramax. Not saying it isn't possible but on the trucks I've worked on there's no way.
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
I can have my zf on the floor in an hour with a lift. That makes it easy. But that's alot of work, seems like my tranny comes out so much anyway it's always out when I need to do stuff like that. And not everyone has l access to a lift
fast03
1,201
60
Rancho Cucamonga
Been awhile and maybe my memory is bad, maybe it was three....I know it was not 12 tho I sprayed all the bolts a couple days before, so that sped things up.
yellowchevy
1,913
59
Louisburg, KS for now
X2
I just did an LLY 3 days ago and it took 5-6 hours to get everything out of the way, turbo pulled, and put on the bench. The 6 up pipe bolts on the turbo were fine but the 3 on the driver side manifold a broke.
I can do an LB7 quicker but those VVT's are tougher.
Yellowchevy.
fast03
1,201
60
Rancho Cucamonga
X2
Yellowchevy.
So yes to be fair Mine was an LB7. A lot less going on with that. If I get around to doing a turbo on this lml its gonna be a bitch
LBZ-DURAMAX
Jared
Feb 12, 2015
193
NW Ohio
I could get all the pedestal bolts coming from above the turbo with a long extension and a swivel socket took me about 6 hrs I'd guess just take your time and you'll be fine not hard just time consuming ;)
WICKED Z
Nov 3, 2014
14
But if it's 2 hours or 6 or 12 , i am not going to have to unbolt the cab and lift it up . Correct ?(a local gm tech , who doesnt do many deisels , said i'd need to lift the cab , he thought )
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
No you do not have to lift the cab or unbolt it
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
The up pipes are 12mm 12 point not 11.....
Remove the glow plug controller off it makes more room
