oil temp sensor install
stibuilder
Oct 17, 2016
239
Snoqualmie, WA
Bringing this back, if you are using the top of the oil filter housing for oil temp readings and you add an external cooler via sandwich adapter are you going to see the oil temps drop on your gauge? If you use that spot what spot would you use for oil pressure?
4,967
yes if you use the correct port and oil pressure sensor stays in the factory spot
13,599
632
You will see pre-cooler temps.
