Nitrous for stock LBZ
JeremyDon88
Feb 6, 2012
297
Well gona build the motor soon as soon this one gives in to my need for speed. Lol just wanted someone with a lot if experience with nos to give me some good info on what route to go. I'm lookin to get my truck in the 10's with stock injectors,pump n turbo!!! Since I have a short bed reg cab and race weight is around 5500 with me in it I should b able to get there with 650-700 hp according to a chart I found that pat provided. ( thanks pat)!! Josh H has took his van into the 10's with basically the same weight and hopefully he could chime in on this and get me valuable info since he run hundreds of 1/4 mile passes on the stock lly with a 2 stage system ! Just really wana know what kit to run and what size noids n jets I need plus how the tune needs to b adj for the nitrous. Seems like a 2 stage with progressive controller with a wot switch and like a Hobbs switch to control when the nos comes on at a desired psi level. I would appreciate any info from u guys and thanks ahead of time! I'm on a mission and I think the truck can do it just not so sure about my wallet at the end!! Haha:D
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
I throw a $hit load of nitrous at my lb7. As long as the fuels their you can makes as much power as you want. Bigger nozzles and less timing:thumb: My only concern would be them weak lbz pistons. Remember even tho egts are lower your cylinder pressure is WAY higher. As for a jet size I run -3an SB line with no jet:D
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
Can't u get any more weight outta that girl? Brian had his truck at 5450 or something and he's got the long girl edition.
JeremyDon88
Feb 6, 2012
297
Ok thanks n yea I don't figure the pistons will like it much!! Lol I know guys are makin 650 easy with a 475 over stocker but just didn't wana spend 4k yet till after I spend all the money to build motor and I think I can get a good kit with all I need to do 650 for under a thousand.
JeremyDon88
Feb 6, 2012
297
Well mayb it will b way under 1k haha. I would just like a progressive controller to control psi during boost so it won't come on straight out of the hole like it would with a wot switch. With a controller u can set it when it won't come on till u reach say 20-25 psi and the wot switch is activated. That way it's past the beams and bf the 60ft line and then the a second stage can come in a lit farther down the track.
Muff
Just Learning
Oct 7, 2013
1,063
Butler, Pa
There's a pretty informative nitrous thread on here somewhere, I believe it's called nitrous for dummies. A lot of info in there also.
Stancedlb7
Feb 9, 2015
649
SLC, UTAH
I run a Hobbs at 15psi. Launch at about 12psi. Progressive controllers are more for gassers. You really need to be able to control intervals
JeremyDon88
Feb 6, 2012
297
100% stock.. I've been checking around tryi to come up sir a good combo but I'd really like to get sum good tunes for nitrous specific runs so that I'm gettin enough fuel to go along with it. Wright now the tune I run is pretty clean so don't think it would do much beside cool EGT's. Does anyone know if josh H sell tunes or just tunes his own stuff?
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
Probably have to sign a waver for the stock engine nitrous tune lol
