LBZ: Mike l trans cooler the same as PPE Coolers??
Columbus450
260
Louisiana
Does anybody know if the mike L Transmission cooler is the exact same as current ppe transmission coolers,Can’t say I noticed a huge 20° temperature drop was just curious if
anybody else would know
torqued2dmax
646
Brookville, PA
I could be wrong but that dose not look like Mike Ls Setrab cooler , it looks more like PPE went to Mishimoto or Ron Davis for there new coolers , many of us know Mikes works very well I can not testify about the one pictured !
Columbus450
260
Louisiana
Is this PPE cooler the same quality as Mikes ? Because I know at one time they were the same reading from previous old posts so I’m confused
Columbus450
260
Louisiana
China you’re telling me this cooler is made in China? I didn’t notice much of a temperature drop with my transmission,Has anybody else had success with The ppe
Columbus450
260
Louisiana
My transmission is not running hot by all means but I did not notice much of a difference switching from this one from a stock one
4,907
at one time they were the same (very beginning), that changed obviously.
4,907
whats outside air temp and whats the trans running at now vs before?
4,907
90* before 183 after 180 not much difference
Sent from my SM-N960U using Tapatalk
That’s fairly cool already. Where guys are seeing the big drop is due to running 200-215* average temp.
Have you ever seen higher with the stock cooler? Is the trans temp now staying closer to coolant temp?
Columbus450
260
Louisiana
Yes temp stays near coolant temp,highest I've seen is 195,was wondering if it would be worth swapping to Mikes cooler or should I keep the Chinese ppe lol
Novak
SQUIRREL TRYN TO GET A NUT
Jun 15, 2015
990
Cloud 9, IDAHO
Did you put the air dams back?? I put new ones in and shed 30 degrees when I did my cooler and the deviant JIC kit. Also wouldn’t hurt to clean out your radiator core too since it’s a shared system.
Columbus450
260
Louisiana
Yes radiator and intercooler is cleaned already be more specific on which air dams are you talking about,Are you talking about underneath the truck I can’t think off the top of my head any shrouds that were in that area
catmenace
255
This made in China comments seem a little much unless you have proof the product is not up to standards. I can remember that in the 60's & 70's everything made in Japan was supposed to be bad. Now that is not the case. Don't forget most things, including your mobile phones, are made in China.
