Lmm cognito braces and steering stab help
Jan 28, 2015
961
Ohio
Anyone running cognito braces and a bilstein steering stabilizer on a lmm? Didn't know if the braces would clear since the stabilizer is bigger then the factory one. Any help would be appreciated.
clrussell
pro-procrastinator
Sep 23, 2013
5,916
381
I think they should, will be same on 01-10 if anyone is looking
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
Will not clear on the NBS trucks. The brace is a better option if choosing one or the other, we have plenty of trucks with huge tire/wheel packages and no stabilizer without issue.
Jan 28, 2015
961
Ohio
What exactly doesn't clear? Does it just hit the stud where I can cut it down or the shock body or what. I just spent 300$ on both so I'd like to try to make them work
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
I would just run without the stabilizer and see how it drives first. I threw mine away doing the same thing you are trying.
5,098
The stabilizer doesn't do a thing if you have a proper alignment and steering parts that aren't worn sloppier than throwing a hot dog down a hallway. It's gm's way to help stop the feeling bump steer but doesn't help
Jan 28, 2015
961
Ohio
What stabilizer are you running? Bilstein 5100? And if it just hits the shock body I ca. Cut the stud out flip the shock around and use bolts. And I only want to make it work because I already spent the coin on it lol.
Jan 28, 2015
961
Ohio
Would you be able to take some pics and send them to me? I haven't tried everything yet put plan to do so this weekend
TowU4Free
#SecretSquirrel
Aug 27, 2011
469
5
Im running the DHD brace and a Rancho stabilzer, I had to cut a little off the brace to make it work but nothing drastic.
mreeves23
Big Hog Customs, LLC
Sep 15, 2011
91
Poseyville, IN
Cognito PISK and the bilstein steering stabilizer clear each other just fine on the LMMs. I have this setup on several trucks. You'll be good to go.
