LLY FICM
1,754
I should be able to back probe the signal wires at the connector. For the current, don't I need an AMP clamp? I believe I have one of the revised Amp Clamps for the lower Voltage. I need to dig it up any way...
As long as your amp clamp can measure DC. Most are only for AC current. Most DVM's require that you put the leads in series with the load to measure the amps. so in your case, if you where to not use an amp clamp, would either have to cut the wires or maybe pull the fuse and stick the meter leads in the fuse slot to measure the current. Voltage drop on the fuse will get you close too
  • fuse-voltage-drop-table.pdf
815
I know we argued with Snap on about this and I believe I have revision D which should be ok for DC
Snap On part number EETA308D
  • ZEETA308D.pdf
1,608
Jason, on the wiring diagrams you posted for that comm issue thread, #52 on the ECM connectors are for the "FICM relay control". Could this be part of the issue with using the LB7 FICM?
1,754
That relay only turns on the power to the FICM. The power to the FICM is in the same pin location. So if the ECM wasn't turning on the relay then the FICM wouldn't get power. Regardless of whether it's an LB7 or LLY FICM installed. It would be an easy test to see if there is power at the FICM fuse bit I don't see anything that would keep the ECM from turning on that relay with an LB7 FICM installed
You can see here that the circuit is the same for both. Just the pin in each ECM is in a different location
1,754
Per this thread, the illusive Ben states that the communication for the LB7 and LLY should be exactly the same (excluding the 01-02 for some modules) and all ths modules should be swappable between them and work just fine. Infact this should be true all the way up to 07 1/2. So if the communication is the same then the last thing I can think of is the actual message or what is being said to or received from the FICM that makes the LB7 not work on the LLY
815
Still can't find the pig tail leads for the meter... :mad: The Amp Clamp will probably work but It was not stored properly and I forgot about the internal 9V battery... fortunately the connection is not corroded. I tried to see if I could get the cord to the meter replaced but Snap on doesn't offer repair on that item...
Decided FK It... I will just order a new one. I Need to find out if they have a replacement lead kit. Neither the part number for the lead kit or the clamp kit show up.
Reactions: 2004LB7
1,754
That's awesome. I don't imagine everyone will come out working but the fact that the first one did is a good sign that "condemned" ones may no be so hopeless after all.
board350
Sep 1, 2023
9
3
Texas
New here, been out of the Duramax scene for a while but got an LLY from my dad. Crank no start situation and found EDU fuse blown and opened the FICM. Found the far right CAP blown. Took them out and cleaned up board as best I could. To test the for shorts I took a wild chance and plugged in FICM and cranked the engine. I just wanted to see if it would still blow the fuse. To my surprise not only did the fuse not blow but the engine fired right up, with no CAPs at all!! I subsequently put two new CAPs in the good spots on the board and left out the blown position. Same result, the engine still runs. I actually drove it today about 25 miles with no issues. I'm not sure if I want to try and put the last CAP back in or just see how long it goes. I'm still in a bit of shock actually. I'd be interested in anyone else's thoughts on this?
1,754
Those capacitors are just the power in smoothing capacitors. Probably not too critical as the Battery probably does more smoothing then the caps woll ever do. But helps with line noise that might make it down the wire as they are run right next to the high voltage injector wires
The larger capacitors are the important ones and it won't run without them
board350
Sep 1, 2023
9
3
Texas
Well I couldn't leave well enough alone. I put in two of the capacitors and it still ran fine. Then I tried to put in the third one where the board had blew out and it ended up shorting it out and I couldn't fix it. I ended up getting a junkyard FICM and replaced all five capacitors on that one and it's running fine. Thanks for all the help.
