LLY FICM
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,332
366
Central OH
Sounds like you should just stick a reamer down the injector bore so you can fit the LBZ injectors in it. Then LBZ ECM and harness. And reluctor right?
Yea couple other things like mentioned, repin a connector or two. I think BT was making a jumper so you didn't have to repin, but I'm sure he's scaled back on stuff. By the time you get all the parts to make the trans work as a stock 6spd you might as well swap the whole thing if it was stock. Probably a moot point by the time I'd switch my "built" parts over. Right now that's even more screwing around compared to getting a module.
With the cost of the used ones, I am surprised they haven't found some one to remake them.
Right. I figure bosch has some patent bs still so nobody can make a board. Hell the Ford FICM kits are everywhere. Friend checked through GM, nobody in the US has a brand new one (at least that's listed in inventory). They were $2600 even when you could buy a new one, which I'd be fine with if it was NEW.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,332
366
Central OH
Has anyone tried reaming a head? I remember talk about turning down the OD of the injector
1,760
Stopped by All American Auto Dismantling. They have one or more in stock but want $2200 each. Damn near the price of a whole engine. Maybe more
820
The LLY FICM has been discontinued for a while since pre pandemic.
As for BT he did do a jumper. I have one. But super hard to get a hold of him and I believe he removed from his site. He is working on newer stuff.
I believe RPM Russ said he can do one as well.
If you decide to go LBZ swap, post up. I may have a few spare things. Also have a pull out too.
1,760
Wait, so the 5 speed TCM is not compatible with the LBZ ecm? Different commutation protocol? Or something else?
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,332
366
Central OH
Thanks for the offer, but it's not in the cards for me right now.
That was the impression I got from reading a few threads, but I could be wrong. I think in 06 was the transition to the newer high speed GMLAN with the twisted pair comm wires
Reactions: 2004LB7
820
Yes I believe that is correct it went to high speed GMLAN Were as the LLY was I believe a combo of Low speed can and Class 2 ? or something like that.
Reactions: 2004LB7
4,980
Yup. Friend of mine did it to a buddies truck. No issues to date. Think he took .015 off or .020. It’s been quite a few years since then
1,614
Im curious. Has anyone taken an LLY FICM apart to see what fails in them? Has anyone taken one apart to see if the internals could be replicated?
I ask bc I have an EE son who loves a challenge.....
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,332
366
Central OH
Not sure what the common failure is, but apparently mine had a capacitor that shorted out and torched the board. Couple videos on YT have shown similar failures. Lady I spoke to at SIA acted like they couldn't replace the processor if it went bad? I was about to ask if they could even fix them at all or if it was a money grab haha
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,332
366
Central OH
I haven't compared a cutaway of both style injectors, but is there a reason the LBZ have a step on the OD? .015 doesn't seem like much to make any difference other than prevent installing the incorrect ones. I wonder if a shop could put LBZ solenoids on LLY sticks
shakenfake
Moron
Sep 15, 2022
204
Shlumpt, TX
Could always do one of those custom PCB websites that often times offer you a free board. Just copy the traces exactly and unsolder/resolder everything over from old board to the new board. If the board is the problem I mean.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,332
366
Central OH
I wouldn't even know where to start with that, or what place would be best
1,760
I would not be surprised if it was a multi layer board as those are quite common on boards of this complexity. Plus unsoldering and resoldering those thousand pin chips is not fun even with the proper heat guns.
Now reverse engineering one would make someone a decent amount of cash at least for a short bit. As long as the chips are not proprietary
I wonder how different, really the LB7 FICM is from the LLY. How much work would be required to convert between them.
1,760
bigclive would be my first choice for figuring out the circuit. He does this quite a bit on his channel. Mostly smaller circuits but occasionally more complex
820
That is a good Question.
See Post 7 here https://www.duramaxdiesels.com/forum/threads/ficms-swappable.39078/
Bdsankey
3,914
1,074
Neenah, Wisconsin
Guys run LLY injectors in LBZs so why can't we do it the other way around? In theory it "should" work as long as the resistances are the same across the solenoids.
Reactions: 2004LB7
