LLY engine build on a budget
stlled
Jan 30, 2014
23
st.louis mo
Sorry if this is off post, Im guessing I should be around 500 hp, COTN tune with garret 4094, 4" with a 3"DP and a fass 150, s&b intake a TMP on a lly. Anyone care to take a guess of just throw her on the DYNO? sorry for highjacking .....
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
My engine is a good 30 psi low on compression on a few holes. Suspecting rings or few melted pistons. Doesn't surprise me from the amount of spray it's seen. Idles a bit rough. One more local race April 18th and she's comin out.
Burn Down
Sep 14, 2008
7,093
Boise Idaho
No way to know without seeing your pulse width and then its still a guess but better educated...:D
cstephens93
Oct 13, 2014
677
30
Tallahassee, FL
So once again, I may be causing more headaches, but when the time comes, I should buy new pistons to build my engine or I should just have my stock ones machined....All of this if I'm trying to make 700hp at most, safely. I saw in a post once that McRat said
The 3 weak points of a Dmax in my opinion are the rods, pistons, and cam key.
Once you settle those three issues you will be fine.
And after that point, the gain in reliability per dollar goes nuts, as does internal engine power-enchancing mods.
CaptPhil
1,012
Delaware
I would just have your stock ones de lipped if you are only going for 700hp. Now if you think you might get the itch to go bigger then I would consider going aftermarket.
cstephens93
Oct 13, 2014
677
30
Tallahassee, FL
What do delipping stock pistons even do? Never been able to find a good explanation. All I ever see are people mentioning delipped LB7 pistons
Burn Down
Sep 14, 2008
7,093
Boise Idaho
De-lipping does two things, one it removes the sharper edge from the piston bowl to reduce the potential of melting, two it lowers compression ratio... Fingers modeling of stock, de-lipped, & oval bowls showed that de-lipped were no stronger than stock and maybe slightly weaker from a cracking stand point.
cstephens93
Oct 13, 2014
677
30
Tallahassee, FL
So if it is no stronger than what is the point
cstephens93
Oct 13, 2014
677
30
Tallahassee, FL
I see that it lowers compression and reduces melting potential, but is this also making them weaker from a cracking standpoint?
Burn Down
Sep 14, 2008
7,093
Boise Idaho
IIRC, according to Fingers piston modeling program he thought they were weaker than stock, from a cracking stand point. You need to remember though that the LB7/LLY piston isn't known for breaking easily de-lipped and shaved...
cstephens93
Oct 13, 2014
677
30
Tallahassee, FL
Hmm I see. Thats interesting. I have so much more to learn in regards to building a motor
cstephens93
Oct 13, 2014
677
30
Tallahassee, FL
So in the future, when i plan on building my motor. I cant decide If I should just try to find a motor with some less miles and build that motor, or If I should just use my motor at who knows how many miles by the time I build it and install rods, pistons and such.
Will I need to bore my cylinders? Or even put new heads on it? I just recently did my headgaskets back in Feb with new grade Cs and ARP studs
