Currently at work trying to order stuff. Does anyone know what size the coolant line is thats below the alternator on a lbz. Comes off the black tube that runs up from the water pump to the thermostat housing. Thanks.
Not 100% sure if they're the same size, but the hose is 1/2" ID on an LMM. It's for the coolant return from the turbo. It slides over a flared barb on each end, and it just has spring clamps from the factory. So if you're going the braided hose route, I'd get some good hose clamps. That hose is a PITA to get to.
