I started the swap. 04 LB7 300+k spun a bearing from water in oil due to injector cup. Friend of mine wrecked his LBZ he bought new, has 100k on it. I got the trans, engine, transfer case, and rear end plus all the wiring, accelerator pedal, steering column, dash console and heater lines. I hope I got everything I needed. Wish me luck My first question is.......the LBZ front cover is cracked due to the wreck and I have the LB7 cover in good condtion. It looks like it will fit but, I was told the LBZ water pump is different. I know the outlet size is different between the two pumps but, since it is going to be using the LB7 radiator is there any way that the LB7 pump will fit in the LBZ cover? Then I won't have to make a reducer for the water hose
