LMM: Kodiak Motorhome CEL data.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Just for info.
Our Kodiak motorhome threw a CEL while it was running hot (240-250°) up a long steep hill. 4,700 mi. Air temp was about 110° F.
First code was P0495 Cooling Fan Speed. Engine data seemed normal.
Second code was P2563 Turbo Boost Control. 3 times it failed. Third time:
Fuel Temp 221° F???
EGT 899°
Desired vane pos 21%
Actual vane pos 45%
RPM 2114
Coolant 224°F
mm3 fuel 101.
Note: Kodiaks have Electronic Engine Exhaust Braking from the factory with a dash mounted switch to turn it on and off. I had it on. They also have manual DPF Regen via another switch on the dash. Regen was not active at the time.
Odd. 221 deg fuel temp?
Perhaps the fuel is being heated by the radiator water? Guess I have to learn about Kodiaks.
slowlmm
Mar 2, 2008
2,582
45
so cal
Rpm 2100 so where you doing about 68mph -70 something mabey. looks as it was basicly throwing a under boost/ over boost . because the desired and actual where so far off ?
slowlmm
Mar 2, 2008
2,582
45
so cal
also i would check the fuel cooler thts some hot arse fuel. I woder if it was atempting regen ?
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Just for info.
Fuel Temp 221° F???
EGT 899°
Actual vane pos 45%
RPM 2114
Coolant 224°F
mm3 fuel 101.
Oh I thought you did for some reason.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
PS - Our weight was about 23,000 lb, and it's the stock 330HP engine and tuning. Plus BarnDoor aerodynamic package.
While 45-50 mph uphill speed is not something to brag about, it's faster than most heavy haulers.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Yeah, you turn the switch on, and the computer figures out when to use it. So you leave it on most the time. Kinda like the Grade Braking on the Allison. It's actually hooked to the Allison Grade Braking also. There is no T/H setting.
Oic, gotcha
