Kennedy lift pumps
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
i meant the big berthas and such the cp3s.
on side note: i find weird, I just wired up lift pumps to a switch(controlling both) turned em on and ran truck....every time I turn the pumps off, the truck gets a bumpy idle, makes me think it's starving for fuel. Turn the pumps back on and it quits, pumps off and bumpy inconsistent idle, but it is very hard to notice, has to be completely silent and I have to be very still.
for some time now, my truck takes longer to turn over, quite a bit longer that it used to or than a new one, even if I leave ignition on a few seconds to let the lift pumps push fuel.
My 05 truck has done that for years now. I have ran 2 KD pumps on my 05 since new....what is happened is my regulator is so use to being forced open by fuel that when you shut it off the regulator is trying to react Hence the lopey idle.....JMO it is getting worse but i dont care.
If you have altered the regulator or B1010 table this could also be a issue.
if you are having starting issues, you may have a small leak.
I like the KDs for the right purpose....My other truck i didnt waste time with them though even the fass 150 was not enough for my wants.
Depends what you need/want.
