LBZ: Injector hold down
Josh2002cc
That Uncle
Apr 2, 2007
1,832
Hey guys, I just completed a head gasket job on my 07 GMC LBZ truck and it now has a small tick. It is coming from the drivers side and from the balance rates it shows #6 being out of whack. Now it did not have any ticks or knocks before tear down and I know 100% the valves were adjusted to GM spec. Here is what I am thinking. I used the GM torque value to secure the injector hold downs but I spoke with someone and they claimed the GM spec isn't enough and I should torque them down more. I think compression is being leaked past the injector causing the faint tick and higher balance rate. FWIW I did use new sealing hardware, both oring and copper washer.
Anyone ever hear of this?
Josh2002cc
That Uncle
Apr 2, 2007
1,832
If the GM spec isn't enough how was it enough when it came from the factory :confused:
Perhaps I used the wrong spec, it was a few days ago but IIRC it was something like 18 or 22 ft lbs. Do you know what the proper spec is? I don't see how your post was of any help though....:confused:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I have seen the same spec , the last LBZ head gasket job we did we decided we didn't trust it , so we went 37 ft lbs ( same as LB7 ) , the fastener , hold down, copper seal, and cylinder head are similar so we figured it would be OK and it was .
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
That's really tight. I'm pretty sure the LB7 uses a bigger bolt for the hold down.
I have never had a problem and I have never torqued them that tight.
13,597
628
I've never had any problems getting the copper to seal using the factory spec of 22 lb ft, but I have had and seen some not seal up well if there is a little debris under the copper. Unfortunately, it usually deforms the copper and requires it to be replaced.
TrentNell
Jul 7, 2008
7,543
slc tuah
I know it is quite a bit above spec but have heard from a few others of having the same problem , probably just as josh stated but we tried it out and it never gave that feeling you get when you exceed a fasteners max torque rating or the heads , usually when you cross the point you feel it in the torque wrench and don't recommend any one with out knowing that feeling trying it , hard to describe the feeling but have been wrenching long enough to trust my hand . the safest bet is always to stay with the stock spec .
Josh2002cc
That Uncle
Apr 2, 2007
1,832
I used torque specs of the famous german goood-in-tight on mine and it has done fine
Yep, the time I don't trust my own internal torque o meter shit leaks.
Thanks for the info guys, I feel i can get the problem fixed using a touch of all the info above. I know the bores are clean but you never know, i'll take the injector out and triple check it.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Once you tighten a fastener to the point in which you exceed its maximum "yield", (stretch in layman's terms) its already to late and the fastener is junk.
Josh2002cc
That Uncle
Apr 2, 2007
1,832
But he said he didn't feel it go past that point. So in his case he is okay.
schulte
Jul 31, 2010
449
CT
Check for exhaust leaks maybe? Did you remove the exhaust manifolds from the heads when you took the heads off? If so, did you replace the gaskets? Also check the up-pipe bolts and gaskets.
You could try shutting off that injector with DVT in EFILive if you have it, and seeing if the tick goes away. If it doesn't, it's probably not injector/copper washer related.
Either way, its pretty quick to pull the injector and replace the copper washer if that's the case, just make sure you clean the surface down the hole before putting in new. If there is, you can pull the glowplug out, rotate the engine to TDC for that cylinder, and push some compressed air in through the glowplug hole (make sure that's clean first of course) to try to blow some of the debris out of the injector hole.
Pondsy
Jan 4, 2008
641
53
Plymouth, MA
When HG were done on my 06 LLY, it developed a ticking sound immediately after. It turned out to be one loose injector and one that had a "nick" in the oring. Replaced both rings and retorqued - all better.
Hope it's something that simple.
schulte
Jul 31, 2010
449
CT
Was there a nick in the o-ring or in the copper washer?
2DMaxx
May 27, 2011
50
long island
hey when you guys ae talking about the injector holddown is that the clamp bolted to the valve cover ? I noticed fuel smell and found that it's coming from passager back far injector where can I get this ?
ripmf666
15,123
14
47
Wentzville Mo
check to see if yours came loose if not we might have a few extras.
9,903
149
x2. I was kind of wondering the same thing. My truck developed a slight tick on the PS after I replaced that manifold. I'm pretty sure it's leaking as I never replaced the gaskets and they looked a little rough.
OT but did anyone ever find out if the injector that you cutout in the DVT is the cylinder in the firing order or the physical cylinder the way they are numbered in the block itself?? Eg: If you cut out #3 is that cyl 3 or the third cyl in the firing order which would be cyl #7? I remember Ben questioning this way back.......
