Injector hold down bolts
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
I lifted one with OEM bolts.. I put 8.8 bolts with washers back in. No problems
I replace rocker shaft bolts with ARP bolts not studs.. They are cheaper than OEM as well
I do already have arp rocker arm studs. I saw the arp bolts but like the studs better.
Cknight199
Aug 23, 2012
1,827
Salt Lake City, Utah
With a lower compression motor, there is less cylinder pressure right? So technically a lower comp. motor would be better on stock hold downs?
Harbin_22
3,858
Southern Indiana
I'm just giving out the info that I have personally used many times on the original OEM bolts and have not lifted an injector, yet. Been reused a dozen times and I am not a retard that puts so much lube on the bolts that it hydraulic locks the bolt from seating all the way. I'm sorry but that takes a real crappy mechanic to be that dumb about how bolts work.
mike diesel
I'm alright.
Sep 6, 2012
4,005
SLC, Utah
Ran the stock hold downs on the new motor even with the compounds and all has been well. But I've got some big fuel going in right now so I said screw It and picked up a set of PDM billet hold downs and arp bolts from industrial injection. Good feeling not having to worry about it anymore.
9,903
149
Are those washers beveled like the head of a stock hold down bolt? Would they work with a stock hold down even?
9,903
149
So I wonder what happens if you "break or lose" them?:D
9,903
149
Are people actually bending the stock hold downs or just bending/breaking the bolts?
