LB7: injector cups Loctite where specifically ??
merlot
Just what I need
Aug 8, 2014
Connecticut
injector cups Loctite where ? on the injector cup cone to head or the bolt holding them
Its my first head job on a duramax and I was told to use it in the forum but just not specifically where or what grade /strength
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,337
372
Central OH
Usually people use red, 242 IIRC. Can also use the green stuff made for interference fits. Can't remember the number. Apply to the taper and the short shank at the end that fits into the head. Can also use on the hold down bolts. Hope this helps.
merlot
Just what I need
Aug 8, 2014
Connecticut
thankyou guys I appreciate it a lot :thumb:
I was thinking that's where but hey you never know and I'm not a know it all either thanks again
hondarider552
Getting faster
May 28, 2008
10,628
33
Arizona
272 locktite only.
I put my cups in a bath of them when I put them in. 9000 miles and tons of nitrous later, no problem. wait 24 hours before adding coolant.
5,019
oh he used alot on them but so do it, its just like an "extreme" amount lol. i wanna know those bitches sealed :D
merlot
Just what I need
Aug 8, 2014
Connecticut
I ended up using Red high temp permatex brand (Napa #) 765-2680 Loctite and just down at the tapered part where it seals and not to much ,just a decent coating , cleaned the heads good with carb clean and a 1 1/4 inch round nylon brush let it sit 24 hours added coolant and no more pressurized cooling system, well live and learn it sucked taking it apart again to do but it was my first head gasket job on a Duramax and alls well now thanks again for the help
