I turned onto reduce power then looked under truck
slavy
Apr 26, 2023
11
Canada
I turned on truck today and it said reduced engine. I look under truck and see this leaking.. anyone know what this is?
slavy
Apr 26, 2023
11
Canada
I turned on truck today and said reduced engine power. I look under the truck to see this leaking? Anybody know what it is?
13,598
632
That thing has been leaking for a while, but it shouldn't cause a check engine light or reduced power.
Reactions: 2004LB7
815
Make Model Year would be good as well. We cant read minds
You need a Magic 8 ball then...
If you want to be a skilled mechanic you will get a set of Diagnostic Dice.... Unfortunately they don't make them any more so they are hard to find. but if you google them you will see how great they are.
1,750
I would guess one or more broken wires or bad connection. Maybe a short. I'd pull the connectors off the ecm and ohm the wires to the FPRV and turbo solenoid. Then check the voltage and ground to each of those
slavy
Apr 26, 2023
11
Canada
I do wanna say I purchased this truck in November was waiting tiles spring to get it on road. I was turning it over during winter and clean exhaust filter came on. I think that’s the p2563. Everything was fine I had it running no problem two weeks ago and then today all of a sudden I’m in limp mode
815
P2563 Turbo Boost Control Position Sensor Circuit
P0047 Turbo/Supercharger Boost Control A Circuit Low
P0090 Fuel Pressure Regulator 1 Control Circuit Open
Reactions: 2004LB7
