Was wandering if there is a head gasket for .020 bore or will the standard bore grade c work?
kenp313 New member Feb 14, 2016 92 0 0 Mar 7, 2016 #1 Was wandering if there is a head gasket for .020 bore or will the standard bore grade c work?
ty_LBZ Camaro killa Dec 6, 2014 297 1 16 Farmington, NM Mar 7, 2016 #2 I used OEM std bore grade C. Still running...
mike diesel I'm alright. Sep 6, 2012 4,005 0 36 SLC, Utah Mar 7, 2016 #3 Use standard bore. They work fine.
hondarider552 Getting faster May 28, 2008 10,628 2 36 33 Arizona Mar 7, 2016 #4 Standard will work all the way to .060 I've heard? I know for sure .040...
malibu795 misspeelleerr Apr 28, 2007 7,853 282 83 42 in the buckeye state Mar 7, 2016 #5 A B C all used on .040 over I have used Bs are cheapest I've you got the protrusion to run them.. I wouldn't run more then .015(stock ish) with Bs
kenp313 New member Feb 14, 2016 92 0 0 Mar 8, 2016 #6 Thanks everybody for the replies. Gonna order me some gaskets
