Got my trans built but shifts extremely hard
justindavis38
Jun 18, 2015
189
29
Hickory, NC
As the title says I finished my trans build with a gmax 5 kit precision converter and input shaft deep pan and shift kit went this morning and had the dealer do a fast relearn with the tech 2 I've let if go through several up shifts easy and it still seems to shift up and down really hard the 1-2 shift feels like the trans is gonna rip out of the truck not to mention if I even let it get up to 1900-2000 rpm then it's awful no DTCs the trans temp is sitting around 132 constantly it's got 6 gal of transynd what do I need to do? Thanks guys
Sent from my SAMSUNG-SM-G890A using Tapatalk
justindavis38
Jun 18, 2015
189
29
Hickory, NC
I went by the trans go kit instructions but I just dropped the vb and I'm about to pul l it apart
justindavis38
Jun 18, 2015
189
29
Hickory, NC
Alright I have it apart the check balls were in the valve with the spring on top of them like the transgo paper showed I can't find my transgo paper now so I'm going online to find another break down to double check
justindavis38
Jun 18, 2015
189
29
Hickory, NC
uploadfromtaptalk1458411678159.jpg is that the correct order they go in? Ball inside the valve spring on ball?
justindavis38
Jun 18, 2015
189
29
Hickory, NC
Yea the orange springs are still in the valve body didn't fish them out didn't think I needed too
justindavis38
Jun 18, 2015
189
29
Hickory, NC
Picture is missing 2 springs.
justindavis38
Jun 18, 2015
189
29
Hickory, NC
Well I've put the vb back in and I'm driving it is I let it shift 1-2 at like 1500 rpm it's solid but it's not slamming the rest are getting better as well but 1-2 was what I was worried about the most I got on it a few times and as soon as it shifts to second it just starts spinning same with third and that's on my 80rwhp tune with out meth spraying but it goes through all of the gears pretty smooth while in it just going in and out of town haul it's pretty rough
Cougar281
1,755
214
St Louis, MO
From the picture in post 8, it looks like the big spring is in the wrong place. According to my ATSG manual, that spring should be with the outer ribbed trim valve, not the inner non-ribbed one. Mike, correct me if I'm wrong (or my ATSG manual).
Sent from my 0PJA2 using Tapatalk
justindavis38
Jun 18, 2015
189
29
Hickory, NC
It was I just had it set aside I have the valves and springs in the right place according to my manual and the transgo instructions.
