Here is more info--I stole it-!
Circuit/System Description
The pressure switch manifold (PSM) is a multiple switch assembly made up of 3 normally open (N/O) pressure switches and 1 normally closed (N/C) pressure switch. Pressure switch 1 (PS1) monitors shift valve 1 positioning, pressure switch 2 (PS2) monitors shift valve 2 positioning, pressure switch 3 (PS3) monitors shift valve 3 positioning, and pressure switch 4 (PS4) monitors the position of the manual selector valve. The pressure switches communicate the positioning to the transmission control module (TCM). The position of the shift valves 1, 2, and 3 is controlled by 3 normally closed shift solenoids. When energized, SS1 directs fluid pressure to shift valve 1, SS2 directs fluid pressure to shift valve 2, and SS3 directs fluid pressure to shift valve 3, which strokes the shift valves. When the shift valve is stroked, an exhaust passage is blocked and fluid pressure to the normally open PS1, PS2, or PS3 increases. When the selector valve is in neutral or any forward position, an exhaust passage is blocked and fluid pressure to the normally closed PS4 increases.
Conditions for Running the DTC
Condition 1
•The test is enabled after engine start-up and runs as part of the transmission hydraulic initialization.
•The transmission fluid temperature is greater than -25°C (-13°F).
Condition 2
•The engine speed is less than 1000 RPM.
•The transmission turbine speed is less than 1000 RPM.
•The output speed is less than 200 RPM.
•Commanded gear is neutral, reverse or first.
Conditions for Setting the DTC
Condition 1:
•At start-up, all pressure switches do not indicate pressure.
•Engine speed is greater than 500 RPM for 6 seconds or 400 RPM for 15 seconds.
•The selected range is not neutral or park for 4 seconds.
Condition 2:
•Any 2 of the PS1, PS2 or PS3 switches indicate that the corresponding shift valve was stroked and a loss pressure is indicated.
•Transmission turbine speed is greater than 400 RPM.
•Transmission output speed is less than 80 RPM.
Action Taken When the DTC Sets
•DTC P0701 is a Type C DTC.
•Range is inhibited, and the driver is required to use the gear selector to re-select the range.
Conditions for Clearing the DTC
Diagnostic Aids
•A plugged control main filter may cause the DTC to set.
•A cracked internal suction filter tube or damaged tube seal may cause the DTC to set.
•A stuck lube regulator valve may cause the DTC to set.
•Must attempt to select range in order to experience a condition.
•May have to wait several hours prior to restarting vehicle to experience the condition.
•This DTC is most likely the result of no pressure and not wiring or the pressure switch module.
