Gateing stock VGT
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
57
San Angelo
tapped in the passenger side header. those were only 3/4 throttle runs, I run closer to 50lbs boost at wot, I just didn't have the room to run full out this morning.
Dozerboy
4,815
396
TX of course
I understand that, but what kind of boost do you see with the vanes practically all the way open. Kind of makes me want to do some logging to compare between MAF, boost, and vane position. I ought to put a driver pressure gauge in my truck to, just temporarily. I do have an extra 100 psi boost gauge laying around.
I've seen over 20psi with the vanes at 5% or less on a 2700PW tune. I was going to get a BP gauge but kind of think its a wast unless your going for max effort. I did a lot of logging and testing boost tables and vane tables and think the vane % is a pretty good indicator of how much BP you have.
I think to many people try and push their turbos to hard. More then a few guys I have talked to have made there fastest passes only running 28psi.
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
I have been doing some more *finer* vane tweaking now that I can actually log it :thumb:
Here is what I have noticed so far (LBZ stock turbo)
At my altitude I seem to need a fair amount of vane position (6700ft)
Working with about a 2250 pulse (stock trans) and a tiny bit of meth mixed in to keep my water injection tank from freezing.
As I increased vane position I am seeing higher flow across the maf. I stopped testing at 42% vane (3000rpms up to 3600, then tapering off a bit).
Down at 25% vane my boost drops, maf drops, and smoke is way too heavy. At 42% I still have a little too much smoke but it's not out of control. The difference in flow from 35% to 40-42% was not real great so I settled at 35% on the big end.
With that kind of vane position I can keep egt's manageable if I dont rev it higher than 3500ish (only do this to avoid 5th). I'm sure my drive pressure is up there, but it just doesn't want to build much boost and smokes pretty bad. I threw lots of fuel at it, with lower vanes and it just smoked worse... no more real flow.
I can hold 25psi up to around 3500. (It will make more boost below 3000 but overall maf numbers are still quite a bit lower there.) Turbo feels tight, and is responsive but I have never inspected the turbine side. I just chalked it up to being the high altitude (though IMO it shouldn't make that much difference).
LarryJewell
Jan 21, 2007
10,152
57
San Angelo
picture.php
Honestly gating a vvt for me probably isnt needed, I think I may have a pretty good setup here. here are 2 screen shots of my drive pressure and boost gauges. The first gauge on the left is the drive pressure gauge, the middle gauge is total boost and the one on the right is boost from the big turbo. Both of these are just 3/4 throttle runs right before shifting to 5th gear.
What I would like to do is figure how to get more boost out of the big turbo (gauge on the far right) while keeping the drive pressure low (gauge on far left) and keep total boost (middle gauge) about where it is..............any ideas
LBZrcks
Jun 2, 2007
5,297
12
SoCal
picture.php
You're actually pretty good already, not even up to 1:1 right?
LarryJewell
Jan 21, 2007
10,152
57
San Angelo
yea, i'm satisfied with the drive pressure vs. the total boost, i would like to see more boost out of the bigger turbo though, say at 50lbs total boost, I'd like to have 35lbs out of the big turbo.
MarkBroviak
DMax Junkie
May 25, 2008
2,076
365
Danville Indiana
Larry, I know you have Cheetah and Mpi but what are they? 71.5 Cheetah and a 75mm/96 1.32a/r for the atmosphere turbo? You may look into upgrading the big turbo.
Bryce418
Still slow
Oct 5, 2009
611
I'm no expert by any means but I would think a 80 would be bare minimum would want under a 71.am I far off in my thinking that something in the area of high 80's would be close to ideal?
